New Member
Old Apr 13, 2016 | 06:41 PM
clmode's Avatar
clmode
Stage III
Smile New Member
New to HD Forum. Could use some info with cam upgrade for an 02 Dyna with 22K miles as to whether it is ok to use the stock push rods when going with a mild cam?
Old Apr 13, 2016 | 07:23 PM
Lou'sUltra's Avatar
Lou'sUltra
Welcome from Ohio. You need to post your question in the tech and mechanical section if you want an answer. More experts will be floating around there.
Old Apr 13, 2016 | 08:02 PM
the wild hog's Avatar
the wild hog
Welcome and as Lou said.
Old Apr 13, 2016 | 08:54 PM
lemonade_07flstc's Avatar
lemonade_07flstc
Welcome to the Forums from Central IL and ditto to above
Old Apr 13, 2016 | 11:47 PM
critter85's Avatar
critter85
Old Apr 16, 2016 | 09:47 AM
clmode's Avatar
clmode
Stage III
Thanks for the suggestion.
Old Apr 16, 2016 | 07:09 PM
fxdlx's Avatar
fxdlx
Yes you can, it's OK. But, there are easier ways to do it. You going to use new lifters?
Old Apr 17, 2016 | 10:33 AM
clmode's Avatar
clmode
Stage III
Didn't know if I had to. If I didn't have to I wouldn't
Old Apr 17, 2016 | 02:41 PM
Bagged64's Avatar
Bagged64
Stock push rods are fine. Would make the job easier if you used asjustables. Change the bearings while you are in there too.
Old Apr 17, 2016 | 07:00 PM
Tommy C's Avatar
Tommy C
You can use the stock pushrods with an aftermarket cam as long as the base circle of the cams measure the same.
