Relocated SuperGlide ignition switch
Old May 20, 2007 | 01:10 AM
ECM's Avatar
ECM
Default RE: Relocated SuperGlide ignition switch
I used the same switch that was under the seat, just moved it and spliced in enough wire to match.
Old May 20, 2007 | 01:20 AM
piniongear's Avatar
piniongear
Hey Mud......
I just gotta ask you.........Ever done a casting of your middle finger? Now that would say a few words if you were running it with a key re-location like ECM made up.
I like the thumb also and the ID is a great feature..........pg
Old May 20, 2007 | 03:05 AM
boogiewithtuck's Avatar
boogiewithtuck
Very nice work - I'm jealous!
Old May 20, 2007 | 06:34 AM
Bobber Rider's Avatar
Bobber Rider
ORIGINAL: mudpuddle
13A and Diablo, thanx for the compliment.
The HD key is set into a resin that I cast into a mold of my thumb.
The key shown above is a oneoff piece that I produced for grins,
and it rides along when I ride.
Normally, I cast the thumbs with a keyring attached.
These are my business cards. Name is cut into thumbnail,
occupation and phone number on the other side.
I make them in all colors, everybody likes my bCards.
mud
Mud
you are truly a genius, and an artist.
this is absolutly amazing work.
what does it take to get one of those thumbs to be sent to Israel?
and another idea, cast a nut into this and use it same way people do spikes, or dice cubes.
Old May 20, 2007 | 08:24 PM
Patch's Avatar
Patch
what did you put in place of the original hole under the seat.
I would like to pit the switch from the baggers under my seat so I can take the key out when I ride...has anyone done or seen this????
Old May 20, 2007 | 10:13 PM
bdn56's Avatar
bdn56
Chip, how much to make another switch plate?
Old May 21, 2007 | 09:39 AM
ECM's Avatar
ECM
Let me look around the shop and see if I have any pieces from the first run I did.
ORIGINAL: bdn56
Old May 21, 2007 | 02:01 PM
flynlow's Avatar
flynlow
I would probably buy one. Yours looks great!
flynlow
Old May 21, 2007 | 02:07 PM
voyager1's Avatar
voyager1
this setup would not work on bob ??? as the bars are different,what think ?
Old May 22, 2007 | 04:25 AM
AZ Rider's Avatar
AZ Rider
I'd buy one.
