01 Dyna oil leak?
Old Sep 29, 2005 | 09:46 AM
warpusher's Avatar
warpusher
Default 01 Dyna oil leak?
My Dyna has an ever so slight oil leak...let me describe it and see if any of yall can help me remidy it.
On the LH side (Primary cover) side, on the bottom of the engine to the rear there is a screw (vertical) that appears to be an allen wrench head. to me it looks like it's not completely in (not flush)
This bolt is located in the general area of the derby cover.
From all I can think of it is some type of oil drain for the primary cover?
Any ideas?
The leak is really miniscule...no more than a drop. but still its a leak.
Thanks for the help!
Old Sep 29, 2005 | 10:45 AM
fxdxsteve's Avatar
fxdxsteve
Default RE: 01 Dyna oil leak?
sounds like the primary drain its a torx actually I used an allen on it and it stripped out I had to remove the primary cover and drill and easy out it to get it out then I put a square head plug in I hate torx screws I change them to stainless allens whenever I can
hawgdawg24
Mar 17, 2017 07:00 AM
gasforblood
Sep 12, 2012 09:21 PM
79lowrider
Sep 28, 2008 06:01 PM
SpursDarkrider
Sep 10, 2008 11:05 PM
QWeeks
Aug 15, 2008 05:53 PM
