Brake noise at low speed
Old Apr 24, 2016 | 11:47 AM
HarleyBob52's Avatar
HarleyBob52
just checked my repair manual,,, looks like there is only 1 anti rattle spring #9
Old Apr 24, 2016 | 12:31 PM
JustOneDean's Avatar
JustOneDean
Originally Posted by HarleyBob52
no just pull your master cylinder off.. there should be a metal clip on each end of the pads... make sure your pads are not loose sitting in the master cylinder
Caliper. Pull the caliper off. OP, the manual will tell you to remove the banjo bolt to do that, because it assumes you're rebuilding the caliper if you're taking it off. You don't need to do that, just unbolt the caliper mounting bolts and support the caliper with a strap or bungee cord if you walk away for whatever reason.
Old Apr 24, 2016 | 12:54 PM
Sammi's Avatar
Sammi
Thanks HarleyBob52
Sammi
Sammi's Avatar
Sammi
Thanks for the tip.
Sammi
Old Apr 24, 2016 | 12:58 PM
Sammi's Avatar
Sammi
BTW, picking up a manual this week.
Old Apr 24, 2016 | 01:56 PM
HarleyBob52
[B]Caliper. Pull the caliper off[/B]. OP, the manual will tell you to remove the banjo bolt to do that, because it assumes you're rebuilding the caliper if you're taking it off. You don't need to do that, just unbolt the caliper mounting bolts and support the caliper with a strap or bungee cord if you walk away for whatever reason.
yes sorry I misstated with the master cylinder,,, that wouldn't do you much good lol
nhhdrider
2014-2024 Touring Models
Jul 12, 2015 08:12 PM
Royal271
Aug 26, 2011 09:42 PM
jcain
Apr 9, 2008 07:59 AM
Custom07RKC
Mar 13, 2007 10:16 AM
TXLowrider
Sep 9, 2006 10:25 AM
