Brake time, fluid expired?
Old May 9, 2016 | 09:32 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by cggorman
Curious if anybody here has ever boiled the fluid in their lines/pistons and had a lever collapse from it...
Taking into consideration "hygroscopic" factors ... yes you could "boil" ( use that term loosely ) fluid that had been compromised. Consider the moisture absorbed into the fluid. It is heavier than the fluid, hence would travel ( over time ) to the caliper area. It's boiling point is much lower than the brake fluid so consequently it would get hot and boil, thereby evaporating, giving you air ( where the fluid had boiled ) in the system.
Old May 9, 2016 | 09:43 AM
HD Pilot's Avatar
HD Pilot
I justed changed my brake fluid with a Mityvac, not too hard. The fluid that came out looked just like the fluid that went in....fluid was about 3 1/2 years old but looked fine - who knows how necessary but why not just change it every 2-3 years, I guess.
Old May 9, 2016 | 10:46 AM
cggorman's Avatar
cggorman
Oh, I know it's entirely possible. I've tracked several cars over the years and seen melted seals/boots and heard of people that lost brakes due to boiling even fresh "dry" fluids. It's never happened to me, however, and I had a car on the track for 6 hours one day. EBC Red pads and DOT4 fluid that was several years old. I've driven EBC Green pads to fading many times. I know cars and bikes are kinda apples to oranges. I'm just curious.
Old May 9, 2016 | 11:25 AM
fxdlx's Avatar
fxdlx
Considering steam takes up 1600 times the volume of water, if water boiled in your brake lines there would be a huge expansion and your brakes would lock up. Also water under pressure has a higher boiling point than water at atmospheric pressure. So if the water boils it expands, the pressure goes up, it condenses back to the liquid state and you're good to go again. Just dump the brake fluid and refill with water.
Old May 9, 2016 | 11:51 AM
Uncle Larry
Remember my hypothesis? yes you could "boil" ( use that term loosely ) The only time the water is "under pressure" is seconds at best ... of course, I guess you could factor anything out to the "Nth Degree" ... I don't know too much about this. I've only been working on brakes for most of my life with an A.S.E. certification. Meh !!
Old May 9, 2016 | 04:57 PM
JohnMn's Avatar
JohnMn
B.S.
You can't equate the expansion/compression ratio of steam and compare it to hydrolic fluids,, that's not comparing apples to oranges it's more like apples to the tree.
Completely different.
Old May 9, 2016 | 05:07 PM
Uncle Larry
Originally Posted by JohnMn
B.S.
You put it much more eloquently than I did. :>)
Old May 9, 2016 | 05:16 PM
fxdlx's Avatar
fxdlx
Come on guys I was being facetious. We know moisture in brake lines is bad. Even if it doesn't get hot enuf to boil. Can we say sieze piston?
Old May 9, 2016 | 05:21 PM
Uncle Larry
Come on guys I was being facetious .... That's easy for you to say ... Your eloquence has been excelled by an exuberance to exaggerate excessively :>)
Old May 9, 2016 | 05:33 PM
JohnMn's Avatar
JohnMn
I've seen rust and pit's caused by water sitting in master and slave cylinders when vehicles have been stored a long time.
I guess to add more here I had a rear brake switch go bad and replaced it last year, so I had to bleed the rear brake,, while I was doing that I flushed the front brake system too just to get clean fresh fluid in it.
It's easy maintenance that should be done every so often.
When I was a kid learning my way around a wrench, the old guy in the neighborhood that helped us drilled into our heads that ya need to be sure they stop before you make'm go. He was into racing stock cars and I think he lost a brother or Uncle because of bad brakes. His lessons have not been forgotten.
