Dumb question:
Old May 9, 2016 | 08:47 PM
Fr8dawg's Avatar
Fr8dawg
Default Dumb question:
What the heck is this:
And what is it for?
Thanks.
Old May 9, 2016 | 08:54 PM
nevil's Avatar
nevil
It's a voltage regulator.
Old May 9, 2016 | 08:57 PM
stilup's Avatar
stilup
I see your regulator that controls the overflow from the charging system,
Old May 9, 2016 | 09:08 PM
cggorman's Avatar
cggorman
Its basically a fancy switch that turns the alternator output off and on to keep the output voltage around 14 volts so you don't blow up batteries, lights, accessories, etc.
Old May 9, 2016 | 10:37 PM
JohnMn's Avatar
JohnMn
The fin's are there because the current flow makes it hot, those are heat sinks/vanes,, keep the thing clean
Old May 10, 2016 | 10:35 AM
archergodwin's Avatar
archergodwin
Short description: voltage regulator.
Longer description: This device turns the ~36volt, 3-phase AC voltage from your alternator, into nice, even 12-14 volts DC to run all your electricals and charge your battery. It does get hot in that transformation process, and is why it has cooling fins.
It's also unplugged
HDPursuit
Electrical/Lighting/Alarm
Aug 22, 2018 12:56 PM
usmc68
Sep 12, 2017 06:59 PM
Jim Dawson
May 1, 2014 04:35 PM
jimsflh
Jun 17, 2010 09:55 AM
ronn39
Feb 2, 2007 04:42 PM
