Back to stock height.
Old May 12, 2016 | 02:03 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Default Back to stock height.
I want to bring my Street Bob back to stock height. Currently it's lowered 1" in the rear and 2" in the front. Can you tell me what size spacer I need to cut to bring a Progressive drop in lowering kit back to stock height?
Thanks, Hogrida
Old May 12, 2016 | 02:31 PM
emperor wurm's Avatar
emperor wurm
Ill trade you my stock rear shocks and stock front springs for your rear shocks....its off a 14 fxdl...
Old May 12, 2016 | 02:39 PM
HOGRIDA_06's Avatar
HOGRIDA_06
No thanks, I have stock stuff still. I might sell the 11" progressives once I buy new shocks. I'll keep you in mind. They'll be cheap.
Old May 12, 2016 | 02:47 PM
NORTY FLATZ's Avatar
NORTY FLATZ
I don't blame you for going back to stock ride height. That's how the motorcycle was originally designed. (Think collision avoidence maneuvers.)
Old May 12, 2016 | 02:48 PM
Warp Factor's Avatar
Warp Factor
It's nice to have a little suspension travel to soak up the bumps, and have enough cornering clearance to be able to take corners at better than granny speeds, isn't it.
The front spacers will need to be a little more than 2 inches. But it's no big deal if you get it wrong the first time, if you use regular hardware store PVC plumbing tubing for the spacers. You can basically set the front end at any height you want. If you don't want to go through much PVC tubing (even though it's really cheap), start high, and cut down as needed.
Old May 12, 2016 | 04:11 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Is it 1.5" PVC? I can't remember.
Jim Dawson
Jul 10, 2013 07:12 AM
5TIME
Mar 22, 2013 07:01 AM
Nick
Mar 25, 2008 10:15 PM
Taterdog
Jan 14, 2007 11:54 PM
ga_hunter
Mar 5, 2005 01:03 AM
