What controls swingarm alignment?
Old Jun 6, 2016 | 10:24 PM
archergodwin's Avatar
archergodwin
3 point drive-train mount. Bottom two are fixed rubber isolators meant to allow motion in parallel with the frame, but restrict it laterally to a small degree. Top mount sets your 'yaw' if you want it stated like that.
The front isolater gives out quick, which allows the rear isolater to act as a pivot point.. moves side to side and the top mount also provides skew at the same time. Can give you a hell of a surprise in a corner, with a slight bump in it....
The rear islolator rarely goes bad... I replaced my front mount with a Predator mount, which puts the rubber isolator in 'compression' and not 'shear' like the stock one... it also has a built in lateral stabilizer.
Old Jun 6, 2016 | 10:28 PM
CJD197's Avatar
CJD197
As boats and planes go...technically the top mount would control "roll". Vehicles usually call it camber. Not that it really equates
Old Jun 7, 2016 | 04:18 AM
cggorman's Avatar
cggorman
I honestly debated how best to communicate the direction of drivetrain movement. XYZ axis and yaw, pitch, roll seemed easiest. XYZ is a little less common and could have required me to define the orientation of the coordinate system. Yaw pitch roll seemed more universal.
Old Jun 7, 2016 | 09:15 AM
Max Headflow's Avatar
Max Headflow
Questions/concerns:
- How is drivetrain yaw controlled and adjusted?
- How does a by-the-book rear axle alignment contribute to a perfect overall chassis alignment?
- How is lateral movement of the swingarm controlled at the trans pivot (I'm sure there must be a bearing pre-load, does the race simply rest against the trans casting?)
In the case of yaw.. I assume you mean rear wheel alignment to the front.. On a stock dyna, there isn't an adjustment to change the alignment. There is only the top mount which allows setting the rear wheel in the same vertical plan as the front..
Rear wheel alignment ideally keeps the rear tire point at the front but do to manufacturing issues, it may be off a little..
Lateral movement on the swing arm is controlled by a timken bearing pair on the left side swing arm mount for 5 speed Dynas.. When they went to the 6 speeds in 2006, I believe they changed over to a pair of spherical ball bearings just like the swingarm on the 02-up baggers..
Old Jun 7, 2016 | 09:18 AM
Max Headflow
What causes the front mount to give out quick?
How do you tell it failed?
Old Jun 7, 2016 | 09:24 AM
cggorman's Avatar
cggorman
The swingarm pivot is well controlled relative to the engine and transmission, but the engine and transmission just kinda flop around in the frame. I exaggerate, of course, but it gets the point across.
Old Jun 7, 2016 | 09:42 AM
Reindeer's Avatar
Reindeer
I think the idea behind the CCE mounts is it allows you to adjust alignment. If I understand correctly, you can just buy this "engine equator" part and have a way to adjust the drivetrain alignment.
https://www.customcycleengineering.c...atorTopLink-97
Old Jun 7, 2016 | 10:48 AM
cggorman's Avatar
cggorman
Yes, I believe that's correct. It looks like it would still utilize the factory mounts which would still allow some lateral movement of the drivetrain. I think a little would be fine, but I don't know how much before the Dyna platform starts to exhibit the various high speed handling issues with which we've become familiar.
Old Jun 7, 2016 | 12:20 PM
harley_jeff's Avatar
harley_jeff
Originally Posted by CJD197
Do you think the wheel is off in relation to the trees, or is the wheel aligned with the trees, but just tracking a bit to the side?
I would sure like to know. Just eyeballing it I can't tell. Any thoughts for some sort of jig to measure it?
Old Jun 7, 2016 | 04:32 PM
Warp Factor's Avatar
Warp Factor
One wouldn't expect much in the way of lateral loads on a motorcycle, unless one is cornering upright, like when a sidecar is attached.
That's not to say that the closer one can come to complete rigidity wouldn't be better for handling, but most Harleys run into cornering clearance limitations, way before they experience flex limitations, unless something is wrong with the bike.
