Time to start researching suspension mods. What are the best options?
Old Jun 15, 2016 | 11:15 AM
Maxxsmart's Avatar
Maxxsmart
I can't remember where I read about those K-Tech Bullets, but I believe they're on the lower ends of performance based shocks... I looked at them for about 30 seconds, and quickly moved on... Must have been for a good reason.
Finding a good suspension comparison will be tough, seeing as how few individuals have the opportunity to test multiple setups. I found that suspension threads seem to end up kind like one of those "best oil to use" threads.
From my hours of research (and I do not claim to even be close to an expert in this subject) I found that everyone seems to be happy with their upgrade to Ohlins, regardless of model. Will the rebound / length adjustable gas & oil separated shock I have out perform the less expensive emulsion versions? Maybe, but I have read ZERO complaints from those that run the emulsion Ohlins. I really think you can't go wrong with any of the Ohlins setups. You don't want piggybacks, so that narrows your choices down to the sub $700 emulsion versions, or the sub $1K semi adjustable shocks.
If you have narrowed your search down to Ohlins, give Howard at Motorcycle Metal a call. I hear he can probably answer some of the more detailed technical questions. The Fuel Moto guys can probably help you out as well.
Old Jun 15, 2016 | 01:30 PM
union53's Avatar
union53
Originally Posted by cggorman
Thoughts or opinions on the K-Tech Bullit? Good info on the web seems kind thin but generally positive from those that have them.
http://www.ktechsuspension.com/produ...rod_cats_nid=8
We put a set of the Bullits on a sportster last year. The initial setup left the bike bottoming out a lot. We upper the nitrogen pressure a bit and haven't heard a complaint since. I think they are a good solution for a good shock in a spot where there isn't a lot of space.
On my bike I put a set of ohlins piggy back shocks. When I was deciding on what to get it was between the ohlins and the ktech razor shocks. The reason I setteld on the ohlins was because they have a hydraulic adjustable preload collar. This was important to me because I'm going from 1 up to 2up on a regular basis and adjusting the spring preload was easier and required no tools.
Old Jun 15, 2016 | 01:44 PM
cggorman's Avatar
cggorman
So the Bullits have a nitrogen charge port?
Old Jun 15, 2016 | 02:39 PM
union53's Avatar
union53
Yes. They don't have a traditional spring. It's an air spring. The more pressure the higher the rate.
Old Jun 15, 2016 | 02:46 PM
cggorman's Avatar
cggorman
I assumed they were charged at the factory and sealed permanently. Any idea what the typical pressure range is for the nitrogen charge? We use a lot of nitrogen at work at high pressures (500+ psig), but I could easily regulate it down to whatever....or use Argon from home.
Old Jun 15, 2016 | 03:35 PM
union53's Avatar
union53
They are serviceable but you do need the adapter to add air. I don't recall what the psi/bar was but it wasn't terribly high. I think it was less then what we normally charge a shock with but I'm not sure.
Old Jun 15, 2016 | 03:41 PM
cggorman's Avatar
cggorman
OK. Thanks. I'm obviously enamored of the Bullits. I'll need to do some in depth research to see if I could live with them. I know K-Tech is a good name but I still like to see what the word on the ground is when a company doesn't provide a lot of technical info.
That's part of my issue with Ohlins at this point. I know they're well respected but they're published info is crap. I like to see cutaways and engineering briefs and charts and graphs and stuff. They just have this sorta, "we're pros, trust us" vibe that annoys me.
Old Jun 15, 2016 | 04:14 PM
union53's Avatar
union53
That's an industry thing. As a dealer you have access to the technical info that the regular customer doesn't get. I think it's a way to support the dealers. Depending on who you buy from you may be able to get the technical printout.
Old Jun 15, 2016 | 08:48 PM
Tiffany1990's Avatar
Tiffany1990
5th Gear
I have Progressive front and rear.
The handling is excellent I think but this is my first Harley and I was expecting it not to handle well. I do know that Dyna's are the best handling of the HD's.
T
Old May 6, 2020 | 10:22 PM
jimbob421's Avatar
jimbob421
Is there a good resource for comparing the dozen or so different Ohlins offerings for Dyna?
motorcycle metal. Ask for Howard. He can make any Öhlins shock to your specs. Look him up.
