You won't have to enlarge center section of the front wheel because 2004-05 Dynas used 1" bearings, but will on the rear because it was 3/4".
After that, the Rear will directly fit with the correct center spacer sleeve and bearing shim (because you are using 25mm bearings).
The Front will need 25mm bearings, correct center spacer sleeve, bearing shim, custom spacers and either rotor spacers or caliper spacers to install on your Mid-glide
