Speed senor? Speedometer??
Old Jul 10, 2016 | 08:13 PM
koshe's Avatar
koshe
2nd Gear
Default Speed senor? Speedometer??
I have a 2000 Dyna Convertible. It has the handlebar mounted cluster.
The speedometer does not work over 10 MPH then goes to 0 when I go faster, odometer goes dark. The engine light comes on when it does this.
Sometimes it wont work at all. The engine light is on then too
Has the 1450 Twin Cam
If it was the speed sensor would the odometer not light up too??
Any ideas???
Old Jul 10, 2016 | 09:33 PM
JohnMn's Avatar
JohnMn
Let's see,, the engine light comes on and you still ride it?
I think it's trying to tell you something.
Old Jul 10, 2016 | 09:38 PM
QC's Avatar
QC
Check your ignition switch contacts for corrosion and such.
Old Jul 10, 2016 | 09:46 PM
CJD197's Avatar
CJD197
My speedo would randomly cut out. It was just the connector to the back of the gage.
Old Jul 12, 2016 | 07:49 PM
koshe's Avatar
koshe
2nd Gear
The back of the speedometer housing has 2 plugs that seem to conceal screws. How do those come off to access the plug?
Old Jul 12, 2016 | 08:44 PM
CJD197's Avatar
CJD197
My gages are mounted in large rubber grommets. You have to twist and pull to work them out. No screws involved. Of course yours may be completely different. Any chance of a pic?
Old Jul 13, 2016 | 02:54 PM
koshe's Avatar
koshe
2nd Gear
Ill take one. Where is the speed sensor in this? Cant seem to locate. Anyone done one of these on a similar bike?
Old Jul 13, 2016 | 07:15 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The speedo sensor is typically on top of the transmission mounted in the trans. cover. You can take it out and clean the sensor head, tends to pick up crap in the tranny. Then check the speedo sensor plug under the seat for corrosion on the pins.
Old Jul 14, 2016 | 10:29 AM
SIDECAR BOB's Avatar
SIDECAR BOB
what code is it throwing? it may answer your question for you .usually the vss will also cause the self cancelling turn signals to fail and or cause the bike to stall when coming to a stop.
Old Jul 24, 2016 | 07:02 PM
koshe's Avatar
koshe
2nd Gear
I just replaces the speed sensor. Sill operates erratically..turn signals wont cancel and the odometer cycles on and off matching the turn signal
lkr0
Sep 21, 2014 07:52 PM
schwingding
Sep 15, 2011 06:26 AM
stocker883L
Jun 20, 2011 08:29 PM
luckydawg110609
Mar 14, 2011 01:35 PM
virtualmike13
Oct 14, 2007 03:47 PM
