speedo quit working got check engine light..
Old Jun 19, 2011 | 09:04 PM
stocker883L's Avatar
stocker883L
6th Gear
Default speedo quit working got check engine light..
Have 2006 883L...Bike has never given me a bit of trouble..Still all stock. Speedo quit working and got check engine light. Bike still runs fine. Just don't know how fast I am going.
Old Jun 19, 2011 | 09:44 PM
WRAITH's Avatar
WRAITH
I had the same problem 2 weeks ago,with my 06 XL1200. I torque the ground connection. The problem seams to have corrected it's self. It could be the TSSM or a bad ground.
Old Jun 19, 2011 | 09:48 PM
cHarley's Avatar
cHarley
If you got an engine light, you need to read the DTC's.
There's a Sticky at the top of this section if you don't know how.
Old Jun 19, 2011 | 09:53 PM
Blaven48's Avatar
Blaven48
Either your wire connections are loose or your speed sensor is bad or has metal shavings stuck to it. Just had this problem with my 48 and pulled the speed sensor and there were some metal flakes on it. Wiped them off and no problems since.
Old Jun 20, 2011 | 07:05 PM
stocker883L
6th Gear
"Preciate the help. Thanks...I'll check the codes and the sensor and the ground.
Old Jun 20, 2011 | 07:23 PM
stocker883L
6th Gear
The TSSM seems to be fine security stills works, everything else on the speedo-dash still works...Bike runs and starts like new as usual...Speedo just don't work..My buddies said I don't need no stinkin' speedo..Just keep up with them and slow down with them...Typical bikers. I am going to pull codes since I have the engine light, and check the ground.
Old Jun 20, 2011 | 07:25 PM
stocker883L
6th Gear
Never had to do it cHarly...Thanks for the info...I printed out the Sticky...Headin' to the garage.
Old Jun 20, 2011 | 07:59 PM
stocker883L
6th Gear
Ran the diagnostics check...Got P0501 and P0502 both related to the speed sensor. One says it low the other says it's high...I'd rather be high, but that can't be good for my sensor? Low or high, sounds like it's confused? Guess I'll pull it and check it out..My old 69 FLH isn't this confusing. Either fuel or spark..Simple. The Sporty runs fine though, just no speedo.
Old Jun 20, 2011 | 08:08 PM
cHarley's Avatar
cHarley
Pull the sensor and see if it's clean or has metal particles on it. If it's clean, replacing it will probably be necessary. If it's got chit on it, clean it and try it again.
Old Jun 20, 2011 | 08:29 PM
stocker883L
6th Gear
Thanks cHarley...'Preciate that...Miss the good old days...Spark and fuel.
terrysillik
Electrical/Lighting/Alarm
Jul 21, 2019 07:35 PM
ChayHay8
Jun 19, 2012 11:35 PM
schwingding
Sep 15, 2011 06:26 AM
sdshook
Mar 13, 2010 05:35 PM
rwjjr
May 26, 2007 04:10 AM
