Fork Seal "emergency"
Old Jul 12, 2016 | 08:32 PM
wyotana's Avatar
wyotana
Default Fork Seal "emergency"
Just noticed today I have a fork seal leak and I leave for a 1500 mile trip day after tomorrow (leaving early morning). I've never replaced seals before but I do all of my own work and consider myself pretty mechanically inclined. So my issue is, assuming my local dealer has what I need, is it worth the risk to pull the entire front end off of the day before the trip (if something gets damaged/stripped I'll be screwed). Or would I be better off leaving it until I get back.
Thanks
Old Jul 12, 2016 | 08:36 PM
MRFREEZE57's Avatar
MRFREEZE57
Thanks
if it is just a little seepage, wait until you return.
Old Jul 12, 2016 | 08:39 PM
CJD197's Avatar
CJD197
My dealer never has anything, and nothing is ever as simple as it should be. I'd wait. Just bring a couple bottles of fork fluid.
Old Jul 12, 2016 | 08:45 PM
Tommy C's Avatar
Tommy C
http://sealmate.net/
^Try this^
Old Jul 12, 2016 | 08:46 PM
cvaria's Avatar
cvaria
Thanks
not an emergency.
fork oil
seals (might as well do both)
pvc pipes from home depot...
anti seize
loc-tite blue
lift and tools...
2-3 hours afternoon job.
your call-
here to help if needed
Old Jul 12, 2016 | 09:35 PM
Ghost_13's Avatar
Ghost_13
"special" tools required
1 3/8" socket for the fork caps.., or a large adjustable - loosen them prior to loosening up the triple clamps
12MM extra long hex wrench / bit for loosening the bolts at the bottom of the forks holding in the internals
Wooden dowel rod - in case the internals spin when removing the bottom bolts
An extra set of hands when reassembling - compressing the springs AND trying to start the tops caps simultaneously is a pita
All in all - fairly straightforward repair
Ghost
Old Jul 13, 2016 | 11:41 AM
BMyers's Avatar
BMyers
Put the top cap on first without the spring in and make a mark on the top cap and fork with a sharpie the spot that the cap threads start to engage. Makes trying to get the top cap to start threading a bit easier once the spring is in the fork.
Old Jul 13, 2016 | 02:02 PM
mattVA's Avatar
mattVA
If just a weep leave it alone. One of those jobs if you haven't done it before you're going to run into issues. Easy to say it's a quick job if you've been in there before, but I remember my first time working on the forks wasn't pretty.
Supposed Harley 49mm fork cap socket didn't fit the top fork nuts, manufacturing defect they took it back and refunded me.
Your fork bushings could be bad causing the fork tube to move off center in relation to the fork leg, taking out the seal.
The stupid dust cover could be so corroded to the fork leg that you won't be able to get it off without some serious persuasion (like on mine, they were destroyed in the process).
Just some free advice.
Old Jul 13, 2016 | 02:48 PM
Campy Roadie's Avatar
Campy Roadie
Worth way more than you paid for it.
Old Jul 13, 2016 | 07:10 PM
103luckygreenDude's Avatar
103luckygreenDude
Before you change the seal, clean the seal with a business card. Take the corner of the card and run it around the inside of the seal.
