Speedometer is a sealed unit?
Old Jul 13, 2016 | 11:03 AM
JamesDyna33's Avatar
JamesDyna33
3rd Gear
Question Speedometer is a sealed unit?
Hello and Thanks to all who replied to my previous topics. Can i get inside the glass on my speedo to clean it? There are smudges inside the glass that must be there from manufacturing. Also there are particles from foam gasket inside which is deteriorating i think. My bike is FXDWG circa 2005. Speedo looks original. Thanks Again, Great Forum!
Old Jul 13, 2016 | 11:49 AM
cggorman's Avatar
cggorman
I started a thread on this topic several months ago and didn't get anywhere. On my gauge (99) the bezel is swaged/rolled over and captures the housing and glass. I considered chucking it up in the lathe and cutting the bezel in half but didn't want to risk breaking something just clean a little clouding from the glass. If you get further, I'm definitely interested in hearing about it.
I've cut open old vacuum motors (diaphragm and push rod) and such to repair those, but starting with a broken thing makes this kind of exploratory surgery easier. Nothing to lose.
Old Jul 13, 2016 | 12:06 PM
jricharc's Avatar
jricharc
I am interested too, my '07 has a small amount of moisture in the speedo.
Old Jul 13, 2016 | 12:50 PM
jz78817's Avatar
jz78817
I swapped in a new speedo on my FLD and agree with cggorman. the metal trim ring around the edge appears to "crimp" the whole assembly together. I'll take a look at the old speedo tonight and see if that truly seems to be the case.
Old Jul 13, 2016 | 12:59 PM
JohnMn's Avatar
JohnMn
Basically, we can't without breaking it.
If we could, it would already be common knowledge and shared freely across the net.
Old Jul 13, 2016 | 01:38 PM
cggorman's Avatar
cggorman
Challenge ACCEPTED! (If only I had a spare. )
I'm very confident I can get one apart without breaking anything, but putting it back together would likely require a custom billet bezel.
Old Jul 13, 2016 | 01:47 PM
F86's Avatar
F86
I would love to get inside my speedo... There's a dead bug right under the glass!
Old Jul 13, 2016 | 03:04 PM
Mchad's Avatar
Mchad
I got a speedo from my old FXD if you want to have a "crack" at it. PM me your address and I'll drop it in the mail. All for the advancement of mankind...
Old Jul 13, 2016 | 03:20 PM
cggorman's Avatar
cggorman
Does it work? I hate to "ruin" a perfectly good speedo. Even well used ones can be worth $100+ on eBay.
Old Jul 13, 2016 | 03:52 PM
Mchad's Avatar
Mchad
Yeah, it's perfect. But I thought they were married to a ECM and couldn't br installed in a different bike? Thanks for letting me know, if it has value, I could certainly use it towards my *cough* third dyno on the 25th...
