no power
Old Jul 17, 2016 | 10:17 AM
mikiee48's Avatar
mikiee48
Default no power
I recently came back from a trip around lake Michigan Went we got back we still had a couple days so we decided to do a short weekend trip washed bike and dried it like I always do went to start and I get nothing no lights speedo instruments no lights or turn signals if I turn ignition switch to acc I do get trip meter and odometer but nothing else checked ignit swich its good checked all fuses and ground point I found nothing any thoughts of what else to check I m guessing its a minor thing but haven't found it yet
Old Jul 17, 2016 | 11:07 AM
nevil's Avatar
nevil
Test the battery. How old is it?
Knowing what model, mileage, model of bike you have might help us out. As well as any mods, especially recent.
Old Jul 17, 2016 | 12:32 PM
mikiee48's Avatar
mikiee48
07 fxd 24000 mi battery was new last year and it tests at 12.9 so its good
Old Jul 17, 2016 | 12:49 PM
nevil's Avatar
nevil
That's good for standing voltage, a freshly charged battery should be 14.5 volts, then can drop to under 13.
What matters is testing it under load. Your local auto parts store can do that.
Old Jul 17, 2016 | 01:59 PM
Max Headflow's Avatar
Max Headflow
Seems a little high for no load and not charging.. Good charging voltage tho..
Easiest thing to do is hook up the voltmeter to the battery, and turn on the ignition. If it drops much below 12V you got issues with the battery.
Old Jul 18, 2016 | 04:38 AM
1stfxdwg's Avatar
1stfxdwg
Default Ground
ill lay odds its the ground cable from the battery. DC voltage is so reliant upon ground circuitry. check where the cable connects to the starter mount bolt. also check the "factory crimp" where the cable is lugged.
Old Jun 5, 2020 | 05:06 PM
Lammy1000's Avatar
Lammy1000
Mikey - Another issue you had and no updates. Fill us in.
8upharleyman
Jul 30, 2019 06:46 AM
chriswillrise
Electrical/Lighting/Alarm
Sep 21, 2016 08:37 PM
reibro
Jul 17, 2014 04:15 PM
06-Bobber
Jul 12, 2010 11:34 PM
karz10
Sep 2, 2008 06:57 PM
