Rear Cylinder Cut Out
Old Jul 25, 2016 | 07:09 PM
Highgrade's Avatar
Highgrade
Default Rear Cylinder Cut Out
Does any one know if on the newer Dyna's the EITMS system has to be enabled by the dealer or do the Dyna's have that system working from the factory?
Is this a feature that is good to have working in the summer months?
Old Jul 25, 2016 | 07:17 PM
MikeySom's Avatar
MikeySom
My 2016 LRS has the EITMS enabled from delivery and has kicked in while sitting in traffic...and yes I think its an excellent feature to have anything that will protect your motor from overheating can't be a bad thing.
Old Jul 25, 2016 | 07:29 PM
shodown220's Avatar
shodown220
My 2014.5 low rider did not have it enabled. I had to get the dealer to turn it on. It has to get pretty damn hot for it to activate.
Old Jul 25, 2016 | 07:32 PM
TinCupChalice's Avatar
TinCupChalice
Just so everyone is clear, the EITMS has absolutely nothing to do with engine temperature management; the EITMS was designed for 'rider comfort', it has nothing to do with overheating of the engine, it was designed to reduce the heat felt by the rider from the rear cylinder; it's simply another solution in search of a problem...
If you doubt me, ask HD themselves
http://www.harley-davidson.com/en_us...conditions.pdf
EITMS is purely for rider comfort. When it
activates and “shuts off” the rear cylinder, it’s
not because the motor is overheating. It’s
designed to reduce the heat radiating from
the rear cylinder to the rider.
Old Jul 25, 2016 | 11:28 PM
canyoncritter's Avatar
canyoncritter
Old men in depends ,women with flaming pads,and states that won't let you lane split,I'm going to blame for it. At least the mo_co is starting to listen again I guess.
Old Jul 26, 2016 | 07:54 AM
Warp Factor's Avatar
Warp Factor
http://www.harley-davidson.com/en_us...conditions.pdf[
Quote:
"EITMS is purely for rider comfort. When it
the rear cylinder to the rider."
What would you expect Harley to say? Are they going to freely admit to an overheating issue?
Old Jul 26, 2016 | 08:01 AM
Back-n-Black's Avatar
Back-n-Black
You can enable and disable anytime you want, All the bikes I test rode at the dealer had it Off....
911pyro
Jul 9, 2022 01:26 PM
billbrummett
Milwaukee Eight (M8)
22
May 15, 2018 11:44 AM
09rkpolice
Feb 17, 2012 06:48 PM
ragtop5
Sep 11, 2009 07:41 PM
FXSTC_Bill
Mar 1, 2009 03:35 PM
