Solid wheel for 02 WG
Old May 22, 2007 | 11:12 AM
PREACHER's Avatar
PREACHER
Default Solid wheel for 02 WG
I'm wanting to change the spoked wheel on the rear of my 02 WG. I don't want to spend mega bucks. Is there a solid take off or exchange wheel from another model that will fit? It is a 16" wheel.
Old May 22, 2007 | 05:42 PM
Rebel Ryder's Avatar
Rebel Ryder
Default RE: Solid wheel for 02 WG
I was wanting to do the same w/the rear blk solid wheel common to the nighttrain. I would think any 16x3.5 stock wheel would do but I don't want to assume. - help?
Old May 22, 2007 | 06:07 PM
West_Tn_Biker's Avatar
West_Tn_Biker
The solid wheel off of a fatboy will work just fine. Make sure the wheel you buy is close to the same year as your WG. I believe they changed axle size to 1" in 99. Also check spacers so rear brake caliber lines up correctly. Should not be a problem and fairly inexpensive to change.
Old May 22, 2007 | 07:00 PM
DGlide04's Avatar
DGlide04
Buy the right year fatboy wheel and bolt it up, it is a direct swap. Look on E-bay, they go for about $50.00 each or less, depending on the condition. Should I say that I'm partial to the look?
[IMG]local://upfiles/1981/8AAABCF048664CA89103270BC6B9C8A7.jpg[/IMG]
[IMG]local://upfiles/1981/224489785FCB4A4EB315F9077F5B926C.jpg[/IMG]
[IMG]local://upfiles/1981/A1A49CF478D34644BC5B7053F93C9772.jpg[/IMG]
Old May 22, 2007 | 09:07 PM
xxxflhrci's Avatar
xxxflhrci
If you want chrome, get a 1200 Custom rear wheel. I put one on my Road King.
For an '02 WG, you need a wheel with bearings for a 3/4" axle. A wheel off of a '00-'04 Sportster will bolt right on.
Personally, if I had a WG, though, I'd get a Fat Boy wheel and have it smoothed and chromed instead.
[IMG]local://upfiles/17633/5BCDB8DFFA0B43AF9055B7621B595DDB.jpg[/IMG]
[IMG]local://upfiles/17633/B324D85CA2054C2B81FF569A3E007BFC.jpg[/IMG]
[IMG]local://upfiles/17633/ACA95CAFB0434B91B1F14267F051D294.jpg[/IMG]
outkast76
Jan 29, 2016 02:47 PM
eafxstc99
EVO
Jan 22, 2014 08:48 PM
Wizard1
Wheels/Tires
Nov 23, 2012 11:03 AM
wideglidebob
Mar 31, 2008 01:49 PM
Fearlessleader
Sep 30, 2007 11:09 AM
