slip on question
Old May 23, 2007 | 12:55 AM
VenturaChop's Avatar
VenturaChop
Default slip on question
whats up guys, just wondering if i get some v and h straight shot slip ons if i would still have to get a stage one ait cleaner and fuel pak???? would i be abel to take out the baffles???? thanks
Old May 23, 2007 | 08:18 AM
jmpancoast's Avatar
jmpancoast
Default RE: slip on question
You will probably get replies saying yes, you at least need a fuel pack of some sory, and you will get replies saying no, the 02 sensors will compensate and it will run fine.
I have slip-ons which have no baffles. You can see straight through the mufflers. The Super Glide did fine when I installed them with no other modifications at all.
I think most will agree that you will be OK with just the mufflers. If you change to a higher flowing air cleaner, then you will need to change your fuel mixture.
Old May 23, 2007 | 08:42 AM
bluesdude's Avatar
bluesdude
I agree.
Old May 23, 2007 | 09:41 AM
fendrix's Avatar
fendrix
You won't need a FuelPak.
I've got these pipes on my bike and didn't do any computer upgrades. I talked to a the local indy wrench and he said that the biggest difference I would notice by upgrading the computer is that the tone of the pipes would lower a bit more. The bike runs a bit on the lean side stock, so I'm sure doing the computer wouldn't hurt...but it's not nessecary. I didn't take the baffles out of mine...not really sure why you'd want to honestly. Sounds damn good and I can't see going through the trouble of removing them would be worth much on performance or sound.
If you get an aiR cleaner you'll need to get a computer upgrade...I'm not sure if a FuelPak would work for that mod or not.
Old May 23, 2007 | 09:55 AM
cadman311's Avatar
cadman311
I have heard of people bikes that glow with the heat if they did not use a up grade of the fuel mix.
Old May 23, 2007 | 02:10 PM
h9ll's Avatar
h9ll
Initially, I was going to order Vance & Hines straightshots for my '07 Street Bob. When I asked about whether EFI adjustments were necessary the guy at the local indy shop told me that a PCIII would be necessary if I didn't want popping and backfiring on de-accel (they also have a roving $dyno$ - which may figure into their answer). After reading some posts here I called Rush and asked about their 2" baffled slip ons. Was told that 2" and below do not require a dealer download if I wasn't adding a high-flow A/C. I emailed FuelMoto and they me told the same story...so I ordered them. Personally, I am not interested in adding any pig-backed fuel management system. When I add the new A/C I'll get the Stage 1 download.
Old May 24, 2007 | 01:55 AM
mikehunthurtz's Avatar
mikehunthurtz
you are gonna love those RUSH slip on H9ll. Got a pair and noticed the extra horsies right away not to mention the bitchin sound output. No ecm adjstment required unless the airflow is adjusted.rock the world bros.!!!
[IMG]local://upfiles/11023/059AF5B55D8949F5809094349FD3C183.jpg[/IMG]
Old May 24, 2007 | 12:03 PM
h9ll's Avatar
h9ll
Yeah, I cannot wait to get them Mike... FuelMoto said 10-14 days as they are built to order. It was good posts from people like you that clued me into Rush.
Old May 24, 2007 | 01:19 PM
johnnychum's Avatar
johnnychum
I have the v&h slip ons and trust me don't remove the baffles they r loud as hell!
Old May 24, 2007 | 01:32 PM
murfe's Avatar
murfe
I have the v&h slip ons.... I've cut down the baffles by about 1/2 and they sound even better now, and no noticeable difference in performance.
