2011 street bob fall away test
Ghost
However, you should be able to lock it up. Be sure your triple tree is un-clamped like it calls for. Go for the low in of the fall away and try the bike. Too tight take all the handling out of a Softail or Dyna. Those tapered roller bearings do not need to be tight.
Check your alignment on that motor and it's mount since that swing arm can be wagging all over the place hanging off the motor on a Dyna setup.
Not sure if taking your hands off the bars to see if it wobbles is a good thing unless you can actually fill it tugging bars. I sure would not be doing that.
You have a heck of a sail in the back with those bags.
worse means it was more violent and it was quicker to get crazy. which was close to the point i had to grab the clutch due to low rpm.
I bought the bike used and it only has 2500 miles so i dont notice any abnormal vibration.
i got it up to 60 mph and let go to see if it wobbles in every gear (except 6th) and it does wobble in evey gear about at the same rpm point- which is that uncomfortable point where you feel like the bike is going to lug so i grab the bars and pull in the clutch. grabbing the bars makes it stop wobbling.
i dont have risers and the handlebars are like a 6 inch straight line at the bottom- which basically means the top of the fork hits them. so the forks are slid down in the tree with a very small gap so they dont hit the handlebars- at this distance i only got 5-6mm when i should have 11-13mm- not sure if that affects anything.
the tire on the mag wheel is more worn that the one on the spoke wheel- both wobble. the other days test i aired up to 34 psi and checked with 2 different gauges.
the roads in italy are the crappiest roads ever old wore out asphalt is all that is close to my house where i have been testing it. ridding home from work one day i tried it and still got the wobble- still crappy road but not as bad as the road by my house.
i have not checked anything else cause its a pain in the a$$. have to remove bags and everything cause of the full fender.
thanks again for everyone's feedback!
First
Mine are a smidgen under 5/16 (~8 MM)
imo 11-13 MM is excessive - others may disagree.., you could always add a minimal riser to gain additional space
As to the wobbles
Warning - be sure to check recommended / max tire pressure on side of tire and don't exceed the Max - 40 psi should be within limits
How are the wheels balanced - weights.., beads.., ride on
If weights.., may need to get them re-balanced
Regardless - have them checked for balance
Try all this ^...,let's see if we gain/ lose anything
Ghost
You loosen fig 6
Then adjust fig 9 to "snug"
Then torque fig 6..., while holding Fig 9 stationary with a punch or screwdriver
Is this the sequence you're following
Reason I ask is that I haven't read where you reference adjusting the star nut (fig 9)
Ghost
With regard to your attached pic, fig.1 shows the upper pinch bolt, correct?
And we are not supposed to loosen this upper pinch bolt (fig.1) to perform the fall away adjustment, also correct?
Thanks
As you tighten the star adjuster nut, the stem and lower triple clamp will move upward (imperceptibly) along with the forks and wheel. The upper triple clamp is then drawn down against the star nut by the stem nut. The upper triple holds the adjuster stationary. If you don't loosen the upper pinch bolts things could bind, bend, or break.
