Dyna Vibration RPM range?
I have an evo softail bobber has a rigid mount 113 ci SnS evo motor in it.. Now that thing vibrates.. Run it to the limiter (7000 RPM ) much and parts start to fall off.. Parts of the motorcycle look like they are possessed.
The vibrations are not at all excessive, just noticeable as the bike is so smooth in the 2500 - 4800 range. If your vibrations are more noticeable on decel you may want to check the vehicle/engine alignment. Before I did the alignment the vibrations were much more pronounced, especially on decel. But a new front isolator, alignment, and shimming the front isolator so it could sit where the alignment wanted it to be turned this bike in to a very smooth machine...
The first LR I ever rode felt great. Rode it out in the country mostly at speeds I suspect were in its sweet spot. Next time I rode one was more city oriented and I thought the ride sucked. Whole thing shook like it was going to come apart. I rode another one in a similar situation and it had no annoying vibes in the handlebars, but the pegs liked to put my feet to sleep.
Earlier this year, I rode a 2015 Sporty Custom. Really liked how light and nimble it felt and the ergos fit me great, but the thing was like riding a buzz saw. Afterward, I test rode a 2016 Wide Glide and that thing was silk. Had much more top end power than any other Harley I can remember too. Even idling wasn't annoying on it.
Even more recently I rode a used 2014 Wide Glide that was equipped very much the way I'd like one. It was way more vibey thru the range. May have been in part a visceral reaction due to aftermarket exhausts that were quite loud and popped like crazy on decel. The suspension also felt much less refined than the 16, which I thought was weird as they seem to be the same thing. I even intentionally rode the '16 over those shoulder wake up strips and it soaked them up well enough that I could sleep right over them. I felt every road imperfection on the '14.
I'm darn near sold on a '16 WG, if it wasn't for the missing brakes. They are so bad, the bike scares me. Love that they're anti-lock, but dang, they're anti-stop too!
And blue jeans.
Even same model to same model.. One of the things that's cool about is how their personality can change.. Hopefully for the better, sometimes for the worse..
Well other than a slight vibe from the pipes when my 2000 FXDX was new, it was very good.. Wasn't till I started modifying things that it started getting bad.. For me the biggest issue was when I added a SnS air filter, tho making it a 116 certainly didn't help..
