Order form Boardtracker HD, or maybe even Surdyke... $45 each. replacement should be less than 20 minutes tops for both.
Have you removed the sensors before the errors? If so, you may have either damaged the sensor portion, or if you used anti seize (which you should have) you may have gotten excess paste on the tips.
That #32700005 part number is shown as correct for both '15's and '13's to replace the front O2 sensor; you should be good to go with #32700005; looks like the only change is from a black housing socket to a grey housing socket
