So many ways to describe the problem, but...
Sorry for the loooong description but I sometimes think it is the only way to make sure I've done my part in describing the whole thing. Plus, I mostly write detailed crap for a living so I'll blame that, too.
Thanks!
Can you be more succinct and less verbose
Motor dying when you blip it (at a stop)
Motor dying after you blip..., then start releasing clutch to take off
Motor dying as you're releasing clutch to take off (sans the blip)
Something else entirely
btw - why all this blipping
1.) it efi
2.) properly tuned bikes need no blipping - they idle fine
Thx
Ghost
Interesting that it's intermittent. I hate intermittent issues. Thinking back, is there any environmental commonality among the "bad days"?
I'm not versed on the technical specifics of the HD EFI system, but if it were a car I'd suspect the idle air control valve system is incapable of "correcting" for your fast near-idle blips.
Since it is "intermitant" could it be fuel quality/brand related?
How about ambient temperature?
How much throttle "free play" do you have, knowing you are " ride-by-wire?"
Does this amount seem to "change" like hydraulic clutch release points do?
Are you sure you are in first gear?
Is one or both brakes dragging more than they should?
These are just some of the things that can cause your issue, after ecm/fuel/spark tables have been ruled out.
I'm an RC also...
I cannot compare mine evenly, since it has a PV map, but it certainly has different mannerisms in the colder weather. I am not much of a "blip" guy, but it certainly does produce an intake cough when done on a cold engine, I noticed. Perhaps in stock tune mode, it would produce a stall.
I would take it to the dealer OR tune it
When I drive a manual transmission in a throttle-by-wire car, it's easy for the ECU to get confused, and "illogical" blipping is a common source for this confusion. The ECU doesn't understand why I'm blipping the throttle if there is no mechanical need to do so, and it tries to undo my input. I suspect that something similar is happening, although of course I could be wrong...
If it doesn't like your throttle blipping, the solution may be as simple as not blipping unless you're rev-matching a downshift...
Maybe Pascal Picotte too, but that's about it.
Well, maybe Scotty Parker too, but that is IT!
LOL 😆
