Fat Bob right fork leg part number
Old Nov 26, 2016 | 07:56 AM
El Chiguete's Avatar
El Chiguete
Default Fat Bob right fork leg part number
Whats the part number of the right fork leg of a Fat Bob? I'm planing a dual disk convertion for my 2011 FXDC.
Old Nov 26, 2016 | 08:05 AM
Uncle Larry's Avatar
Uncle Larry
48739-08 SLIDER FORK - RIGHT HAND
http://www.outpostalaska.com/OEMpart...fFORK%2c_FRONT
Old Nov 26, 2016 | 11:37 AM
oldbie's Avatar
oldbie
Does the Fat Bob slider have the same finish as the FXDC?
Old Nov 26, 2016 | 03:56 PM
Nemosengineer's Avatar
Nemosengineer
You might want to consider using a Low Rider right fork leg instead of the Fat Bob right fork leg. The Fat Bob leg has the caliper lug mounted about .140 of an inch inboard from where it needs to be for a mid glide conversion. Also the fender mount lug has a different bolt pattern thas is not easy to accommodate. also verify the fork leg is compatible with your damper rod assembly as I think some changes occurred with the later parts.
This is what my Fat Bob conversion looks like, machine work was required on both calipers, I did this before the Low Rider was introduced. If I did this conversion today I would do it differently.
: Mike
Old Nov 26, 2016 | 04:03 PM
El Chiguete
Thanks for pointing that out, so I guess it will be a Low Rider leg that I need to consider looking for one.
rayny1014
Mar 10, 2016 09:14 AM
sharkey
Sep 4, 2015 10:48 PM
justin_ryan
Aug 6, 2015 08:10 AM
torpidrabbit
Jul 22, 2014 06:21 AM
ExDucRider
Nov 20, 2013 05:50 AM
