FXDL Wheels on FXDF Sliders on FXDB..
Old 01-24-2017, 04:14 PM
Nemosengineer's Avatar
Nemosengineer
Nemosengineer is offline
Hi Abez.
This is just supplemental information to what multihdrdr has already posted.
The Fat Bob legs are a old school way to get dual discs on a Dyna. A few photos to show what I had to do to get the XR calipers and the stock fender fitted to the Fat Bob legs. The XR calipers are excellent regardless of what legs you use and are every bit as good as the four piston Brembos.
Machine work on the calipers. Lots of material on the extremely beefy XR caliper lugs, no strength is lost by cutting them down.
Required modification to the fender mount.
End result...
: Mike
Old 01-27-2017, 01:18 PM
MolonLabe1977's Avatar
MolonLabe1977
MolonLabe1977 is offline
but you gotta watch Californians in general and San Diegoians in particular
Hey!! I represent that comment!
Old 01-29-2017, 10:49 AM
abez's Avatar
abez
abez is offline
Hey thanks to everyone's comments and help.
I ended up milling down the mounting points on the fork sliders. I took them to my local machine shop and had the sliders milled down .040 on the right side and .187 on the left. the shop was able to leave most of the mounting tabs intact and milled down around the hole that the bolt goes through so the calipers are seated in closer to the sliders and away from the rotor.
The calipers now fit perfectly on the rotors and seated on the sliders.
THANKS!!!
Yes, 3/16" is right there
I should add that Right-side needs a little removed also if you want to do it "Right"...just not as much.
A pretty close approximation (which really will you get there) would be to remove:
approx .180" (maybe up to .190") Left-side (clutch lever side)
approx .040" (maybe up to .050") Right-side (brake lever side)
FWIW, I am going to perform a super precise measurement soon, but won't be tomorrow
Attached Thumbnails FXDL Wheels on FXDF Sliders on FXDB..-20170127_152600.jpg   FXDL Wheels on FXDF Sliders on FXDB..-20170127_155357.jpg
Nemosengineer (01-29-2017)
Old 01-29-2017, 10:53 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,237 Likes on 1,813 Posts
Excellent! ...Did you also slit/slot the fender mounts like nemos is showing?
Old 01-29-2017, 10:58 AM
abez's Avatar
abez
abez is offline
I have not yet, but I will be doing that.
Thanks Nemosengineer for the advice. I will be cutting my fender to line up with the mounting point holes.
Old 01-29-2017, 11:34 AM
multihdrdr's Avatar
multihdrdr
The benefit (IMO) of using the top hole of the fender and slotting the bottom so that you catch the bottom hole, is that since the Fat bob slider's top hole is lower than the other models, that then lowers the fender and reduces that tire-to-fender gap you had with original sliders...looks better to me
abez (01-29-2017)
Old 01-29-2017, 01:18 PM
Nemosengineer
THANKS!!!
Hi Abez,
Great Job!!! One more way to skin that cat.
: Mike
abez (01-29-2017)
Old 05-06-2017, 09:49 AM
Lambda's Avatar
Lambda
Lambda is offline
Im bringing up this thread because I have made the mistake and bought a set of chromed sliders on ebay from a fatbob for my FXDC Dual disk conversion just to find out the fender and calipers issues.
The fender part is easy, however on the caliper part some meat needs to be shaven off, could using a dremel to do such task would be a good idea? I have certain doubts about the result being completely flat so the caliper sits correctly on the slider, else i'll have to find a machinist here that can do this work.
Any insights are welcome.
Nemosengineer
07-21-2018 09:33 AM
chriswillrise
09-19-2016 11:59 AM
emerican19
01-20-2016 01:51 PM
streeter
03-30-2013 10:17 AM
Muddyape
12-24-2012 10:57 AM
Quick Reply: FXDL Wheels on FXDF Sliders on FXDB..
