fxdx front fork options
Old Sep 14, 2016 | 10:40 PM
chriswillrise's Avatar
chriswillrise
Default fxdx front fork options
I have an 03 fxdx that was in a small front end crash. Previous owner replaced the front forks with a single disk style. I would really like to get some stock duel caliper forks back on but they seem to be selling for like 700 bucks. Any other good options for a dual caliper front end? First harley so sorry if I sound stupid
Old Sep 14, 2016 | 10:47 PM
gartec81's Avatar
gartec81
just buy a new lower leg and get it installed
you will need:
39mm right side lower leg
caliper
brake pads
rotor
brake lines
Old Sep 14, 2016 | 10:50 PM
sn95bullitt's Avatar
sn95bullitt
you will need:
caliper
brake pads
rotor
brake lines
That easer said then done. You need the matching right leg. Do you know what model the forks that are on it now are off of?
Old Sep 14, 2016 | 10:53 PM
chriswillrise
Thats the problem i have no idea what brand they are, ive looked for markings and ive found none
Old Sep 15, 2016 | 11:19 AM
multihdrdr's Avatar
multihdrdr
Brand?... Odds are they are just OEM sliders (which would Showa, btw)
Post a good photo(s) of that Left Slider... filling the frame with slider, caliper, axle
It also appears to have chrome or polished sliders...which could change some decision making
Old Sep 15, 2016 | 07:02 PM
chriswillrise
they do not have the preload/dampening adjustments that the stock fxdx forks had. I will take a couple pictures and post em up
Old Sep 15, 2016 | 07:11 PM
chriswillrise
Old Sep 15, 2016 | 07:27 PM
skinman13's Avatar
skinman13
that looks like the polished OEM tubes on my 2001 FXD
Old Sep 15, 2016 | 08:13 PM
gartec81's Avatar
gartec81
part shown as #35 46022-00
http://partsfinder.onlinemicrofiche....TEERING%20STEM
surdykes price is 220.66 -
https://www.surdyke.com/AdvPartInfo....umber=46022-00
you will still need a rotor and a fork seal kit to install.
these are the model numbers and prices for brand new. you can search ebay and get this stuff for much cheaper. however, i think a new right leg will be better and better priced than what is on ebay right now
  1. slider - 46022-00 - $220.66
  2. caliper - 44023-00A - $187.99
  3. pad kit - 44082-00A - $47.49
  4. caliper brake lines -45194-99- $160
  5. master cylinder 11/16ths with lever -45013-96b - $108
Old Sep 15, 2016 | 09:12 PM
nevil's Avatar
nevil
I installed a Big Brake rotor from Arlen Ness. It's 15" and comes with a bracket for mounting the caliper. With the EBC pads there's a real big improvement in braking. Cost me $261. Sure, it's not a dual caliper set up but it's a lot cheaper and easier to do.
