What stage kit?
Old Feb 24, 2017 | 09:40 AM
PCRockin's Avatar
PCRockin
Stage II
Default What stage kit?
I bought a 2007 Street Bob and they said it had a stage 4 performance kit in it. What kind would it be, or is there a way to find out. They don't have any documentation on it, and the Harley place was no help.
Old Feb 24, 2017 | 11:01 AM
JohnMn's Avatar
JohnMn
Performance Up-grade kit's are available from many suppliers, and I don't think any of those suppliers manufacture each and every component.
They will get pistons/heads from one manufacturer, cams from another, rings and valve springs from another,,,etc. Then compile it all to sell as a kit.
Without the sales receipt, there really is no way to tell.
Old Feb 24, 2017 | 11:57 AM
nevil's Avatar
nevil
There seems to be differences in what's involved, but a stage 4 is usually a high flow intake, cams and headwork, exhaust and a tuner, possibly a big bore kit. The intake and exhaust are easy enough to spot, as would be a piggy back type tuner. If it was flash tuned the dealer should be able to tell you that. As for the internal mods, that will take a bit of internal inspection to find out.
If "they" installed any of it they should be able to tell you what they did, even if they don't have invoices for the work and parts.
Old Feb 24, 2017 | 02:41 PM
HrdNox's Avatar
HrdNox
And here lies the inherent problem with putting a nomenclature in front of the word "kit".
Old Feb 24, 2017 | 03:13 PM
cggorman's Avatar
cggorman
I understand the marketing power of the "stage x" upgrade, but I always hated it. Probably my hot-rodder upbringing.
Old Feb 24, 2017 | 11:36 PM
multihdrdr's Avatar
multihdrdr
You can make up your own "Stage" kits
I added special valve stem caps..."Stage 1"
Thinking of more Mods now
Old Feb 25, 2017 | 12:25 AM
JohnMn's Avatar
JohnMn
No No, If you go any further it's a "Build" !
Old Feb 25, 2017 | 11:52 AM
hdbob2006's Avatar
hdbob2006
Find somebody that has a 'stage 4' and race him.If you keep up,you have a stage 4.
Old Feb 25, 2017 | 12:34 PM
cggorman's Avatar
cggorman
If you bore, stroke, cam, headwork, intake, exhaust, and tune all at once...it's one stage, right?
Old Feb 25, 2017 | 12:55 PM
multihdrdr's Avatar
multihdrdr
Yes, then add valve stem caps..."Stage 2"
