Question for all you wire wheel owners.
Old Feb 28, 2017 | 09:26 PM
W.Glide's Avatar
W.Glide
I agree. The spoked wheels do look really good on these bikes. I may just save my $$ and run on the tubes for a while as much as i'd like to go tubeless till I make up my mind on what to do. I just got thru putting the Ohlins Blacklines on the back and NIX22 fork upgrade in the forks, and man what a difference in ride and handling! It doesn't feel like the same bike.
Old Feb 28, 2017 | 09:33 PM
TinCupChalice's Avatar
TinCupChalice
Now throw some Pirelli Night Dragons on her; 180/60-17 rear and a 90/90-21 front and take real advantage of that great suspension upgrade you've done
Old Feb 28, 2017 | 09:50 PM
Tall Timber's Avatar
Tall Timber
I like the last one best.
Old Feb 28, 2017 | 10:13 PM
bl_dg's Avatar
bl_dg
Things have been on hold for awhile, but plans are Deuce rear and 23" spoke front.
Old Feb 28, 2017 | 10:24 PM
lh4x4's Avatar
lh4x4
All H-D spoked wheels from 2014 are are tubeless. Some select models prior to then.
Old Mar 1, 2017 | 06:55 AM
cvaria's Avatar
cvaria
if what you are saying is true, his 16 fxdwg should be tubeless then. but, i'd verify
Old Mar 1, 2017 | 07:21 AM
cggorman's Avatar
cggorman
There are countless home-brew, DIY, and commercial systems available for sealing conventional spoke rims/nipples. Google can help. Be sure your rim has the correct bead retention profile.
Old Mar 1, 2017 | 09:52 AM
Yukon42's Avatar
Yukon42
Remove tire from spoked wheel; generously apply flex seal to inside of wheel, let dry; remount tire. Sounds good anyway!
Old Mar 1, 2017 | 10:04 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by cvaria
i...
call them and ask for Bat Masterson. he will walk you through...
And Never, I repeat NEVER...ask for Mat Basterson
Old Mar 1, 2017 | 10:05 AM
cggorman's Avatar
cggorman
Silicone sealant will do it. Technically. Just don't ever try to turn the nipples and expect to stay airtight.
