Recommended tools for front end R&R?
Old Mar 2, 2017 | 01:04 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by cggorman
Looks Mo Pro gets my nod for neck race puller. I'd rather not hammer the race out...
$60
^^^ This
VVV Not That
$25-$40 (requires hammering)
... Reports of not fitting well into void under Race
Or $25-$40 (requires hammering)
Old Mar 2, 2017 | 01:14 PM
cggorman's Avatar
cggorman
Thanks. That's the kind of info I need. Cheap yet functional. The Pit Posse (lower) design looked a little sketchy plus I don't like hammering on things if I have a choice.
Obviously I ~could~ just use a brass rod or drift punch and just walk the damn things out, but the neck is nice and tight now. I want to keep it that way.
Old Mar 2, 2017 | 01:21 PM
cggorman's Avatar
cggorman
I haven't poked around my new front end yet to see what, if anything, I'll need to get the top tree off. I know the tube clamps are torx. I've got that covered. The jam nut and adjuster are still hidden under the cap. I haven't yet looked at the tube caps either. I'm chomping at the bit to get the service manual. Hopefully today.
Old Mar 2, 2017 | 01:28 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Sounds like quite a project you have. Using the same wheel/caliper?
Old Mar 2, 2017 | 01:32 PM
cggorman's Avatar
cggorman
Nope. Everything from the tank forward is getting replaced, less the frame. Customized tank, full compliment of Motogadget electronics, hybrid DF/DWG dual disc front end, custom wheel, 7" headlight, bars, grips, hand controls, etc.
Old Mar 2, 2017 | 01:33 PM
multihdrdr's Avatar
multihdrdr
Obviously I ~could~ just use a brass rod or drift punch and just walk the damn things out...
Actually, I don't think they are really even accessible. It's not like the access on an automotive hub
Old Mar 2, 2017 | 01:34 PM
cggorman's Avatar
cggorman
Hmm... Might could be. I've obviously never done this before.
Old Mar 2, 2017 | 01:36 PM
multihdrdr's Avatar
multihdrdr
You probably would need to be "committed", if someone used a 99-earlier caliper on a 2000-later slider.
The other way around is a different story
Old Mar 2, 2017 | 01:43 PM
Jackie Paper's Avatar
Jackie Paper
Just a thought but depending on how many you plan on doing in the future, not sure if you need those bearing tools. Autozone has free loaner stuff and with that and a piece of all thread should suffice.
Old Mar 2, 2017 | 01:44 PM
multihdrdr's Avatar
multihdrdr
You need 12mm Hex driver for the Damper bolts...long enough to clear the Left slider casting (look at your slider)
