Break in Question, new info
Old Mar 5, 2017 | 04:41 AM
JayStronghawk's Avatar
JayStronghawk
Lots of arguments on Engine Break In .. Only 2 I am sure of not to do .. Never Ever Lug the Engine .. Do Not Maintain a Steady RPM for a long length of time .. Vary Your Speeds and Downshift early enough to avoid Lugging but not so high as to cause Engine Braking .. This has worked well for me for a Lot of Years .. Far as Changing Oil always did it at 500 Miles rather than 1,000 ..
Old Mar 5, 2017 | 05:43 AM
HKMark23's Avatar
HKMark23
Originally Posted by RiverSouth
I did a search and found some older threads, I was wondering if there is any new info or consensus regarding the break in process.
I got a SB at 5 miles, and have been doing the 'baby' porocess, meaning no rpm more than 3500. It has 37 miles on it now. Then I came upon the "run it hard" way...
Question: Dont they break the engine in the factory? I assume after they put everything together they run the engine and seat the rings?
If so, doesnt that make whatever breaking process you choose irrelevant?
Look at it the other way around bro. Is there any evidence at all that reading the manual and breaking in in accordance with that will do harm ?
The trusting of **** dyno's is a selective thing around here so, can you find actual Dyno printouts comparing identical machines, one which was borken in per manual and the other broke in hard ? Until you do, the only durable evidence seems to be that manual.
Old Mar 5, 2017 | 06:31 AM
Mchad's Avatar
Mchad
Mike, I agree with the 100 mile oil change, it makes sense. You expect lots of metal shve off the piston walls.
But why first 50 100 miles rings seat? I assume its much earlier, first 10-15 miles maybe.
I'm a fan of oil changes, but realistically, no one uses "break in" oil anymore, and the filter will catch anything big enough to be called shavings, won't it? Or is the assumption that there will be so much the flow can be reduced and go into bypass?
Old Mar 5, 2017 | 06:51 AM
Iceman24's Avatar
Iceman24
MotoTune New Engine Break-in: http://www.mototuneusa.com/break_in_secrets.htm
- Warm-up motor
- Find quiet/long/straight stretch of hwy.
- Get to 30mph in 3rd
- Run from 30-60-30 (crank wide-open throttle between mph cycles) x10 times
Best to do this right away, when motor's fresh, to seat the rings. Once complete, I went home & changed oil...because I'm **** that way.
Old Mar 5, 2017 | 07:06 AM
TinCupChalice's Avatar
TinCupChalice
- Warm-up motor
Exactly what I came in to post! MotoTune RPM drills, then a complete change of all 3 fluids at 20 miles on the ODO; every break in, that's the pattern. Nothing left to add but a thanks and a knowing head nod...
Old Mar 5, 2017 | 07:14 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by Mchad
Lots of different opinions on this. Whenever I get a new bike I usually follow the manual, except for a few hard wot pulls on the ride home from the dealer, and once in a while during the first 100. Only when the oil is nice and hot.
Buddy of mine used to be service manager at a bmw dealer and he swore the best motors were the ones the sales guys beat the hell out of right off the delivery trailer. Fwiw....
You do realize that the best motors to a service manager may just be the one's that they work on regularly!?? ....
Old Mar 5, 2017 | 09:10 AM
TUCCI's Avatar
TUCCI
Ive always run the engine the way its going to be run without lugging or over-reving past 3500RPM. You can run it at freeway speeds and still keep it under 3500rpms. Just dont squeeze too much horse power till it starts to feel like its loosening up which from my experience is around 500 mile range depending on the engine.
Another controvertial point arrived from experience; if you want to keep the motor running quietly, resist using synthetic oil sticking with a good conventional oil....now Ive done it, I started an oil thread.
Old Mar 5, 2017 | 02:43 PM
kontiki's Avatar
kontiki
The process for breaking in an air cooled motor is bit more **** than one for a typical water cooled motor. Same thing with airplane engines. I followed the recommendation with mine. It was not any hardship and all the break-in miles were done in a couple weeks. I've had zero issues with the motor.
Old Mar 5, 2017 | 03:02 PM
Suede Blue Man's Avatar
Suede Blue Man
I followed the manual directions for the break-in when new but when I built the motor last year for break-in I used this oil recommended by Baisley. I changed the oil and filter a couple of times for break-in and went with more the MotoTune technique.
Old Mar 5, 2017 | 04:06 PM
Jackie Paper
Well we just went from a bunch of opinions on something other then what Harley engineers say to an oil thread....
