09 streetbob
Old Mar 10, 2017 | 06:22 AM
Reaper2234's Avatar
Reaper2234
Stage II
Default 09 streetbob
Recently changed the clutch cable and I noticed that the clutch lever was pretty much all the way out before the clutch would grab. Fast forward a day, started to ride and bike just felt weird, so I turned around and went home. Once home the tension on the clutch lever was so bad I could have taken the lever off. I opened the right side of the clutch assembly and on the rod there are to washers and the bearing thrust was sheared off. my question is can I just replace the bearing thrust or do I have to replace the whole rod assembly.
Old Mar 10, 2017 | 11:15 AM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
This was posted in Touring. Moved to Dyna section.
Old Mar 10, 2017 | 08:51 PM
Nemosengineer's Avatar
Nemosengineer
Bump
: Mike
Old Mar 10, 2017 | 09:01 PM
Nickd2689's Avatar
Nickd2689
I would replace the assembly if it were me. I'd also pull the outer primary cover and maybe even the clutch assembly and make sure there wasn't any other failures or worn parts.
aces&8s
EVO
45
Jul 4, 2019 06:34 AM
OldWheels
Mar 18, 2019 10:17 AM
krh1326
13
Aug 18, 2010 07:16 PM
fgall4355
Jul 1, 2009 04:26 AM
zap89
Feb 14, 2007 09:18 PM
