help
Old Jun 2, 2007 | 12:28 AM
06 lowrider's Avatar
06 lowrider
Default help
i have a 06 lowrider and i want to have a wide glide front end put on and 21' wheel also would like to lower it even more and would like some more lenght i get all kinds of answers when it comes to raked trees some shops say ok up to 5 degrees some shops say not to use them at all this is getting confuzing i just want to make the bike look long and low and still have a great handling bike what should i do ?/ thank you
Old Jun 2, 2007 | 12:47 AM
05 Wd Gld's Avatar
05 Wd Gld
Default RE: help
All I can tell you is that you need to make sure that your trail in the steering stays within the parameters that establish good handling. I cannot tell you for sure what that would be either. You need to be talking to someone who commonly does frame work and custom work on bikes. They will be able to tell you about the geometry that is needed to maintain a safe bike.
If while talking to them, they seem unfamiliar with that, then they most likely are unfamiliar. You will also need to do some research either at the library or a good book store or even on the internet about the geometry that you will need. If you don't educate yourself then you won't know if the service department is BS'ing you.
Good luck.
Old Jun 2, 2007 | 01:04 AM
hammerhead's Avatar
hammerhead
Default RE: help
Couple guys on this forum have swapped to wg trees and 21s. Gain in length was minimal...couple inches.
95wideglide
Jun 11, 2014 09:48 AM
kennygsuperglide
Dec 4, 2011 09:15 PM
papa_j
Sep 3, 2010 09:14 PM
dirty78ironhead
Ironhead
18
Jun 3, 2010 07:01 PM
06 lowrider
Jul 3, 2007 05:33 PM
