S&S 124 Question
My first thought was that I would have the barrels honed and fit new pistons, while also bringing the heads in for deposit removal and possible guides/seals if necessary. Then I started thinking, why not just drop on a set of S&S 4" (100 CI) barrels and pistons instead of messing with my barrels? Anytime stuff has to come apart, I like to find a gain..
But that would still leave the possibility of valves needing attention, and I've been wanting to upgrade my cam chest which I don't think has ever been done...
Obviously the cost is not equivalent, but I started thinking... If I have to pull the heads off, rebuild the rocker boxes, fit new pistons and barrels, open up the cam chest... Would I rather spend the time on an engine swap that ends up with well engineered matching components, a healthy bump in power, a two year warranty...
I'm not dying to spend the money, but I could...
Just pondering for now, but I need to determine a course of action and start moving... I'll start with a compression check over the weekend.
I probably should've noticed things going awry sooner, but the bike runs pretty well, oil smoke hasn't been very noticeable until just recently, and oil consumption isn't noticeably different... Maybe I'll open it all up and then decide how best to proceed.
You could go bigger cubes and use your current heads-Andy Simon is an amazing HP guy and if he did the original heads, they should be fine with a refresh (springs, valves, guides) in a slightly bigger cube package. Then, 120 HP or so is easily within reach and it won't hit your wallet as hard...just remember, if you have a stock lower end...well, do you feel lucky?
I have had an 80, 88, 96, two 124's (stock and built) a 126 ( my favorite and current motor in both stock and currently built forms), and a 131", and can tell you, it gets pricey fast, real fast. The Mik 42 ain't gonna cut it for a 124 (but based on your riding style and goals I would put a 126" S&S in there), so bye bye Mik-way too small. Need new pipe, full clutch (not just a pack upgrade), induction and prepped carb, chain drive, and tune for starters.
So, no, another grand on top of the motor ain't cutting it if you want to do it right-but, when done, it will be one nasty Dyna...
Depends on how committed you are, both with your wallet and your goals.
I'm just doing some mental figuring, which I often do, and it often goes nowhere in reality...
BUT...
If one were to drop a new S&S 124 into a bike like, for example, a 2000 FXDX (like the one I happen to own)... What sort of budget beyond the cost of the engine itself would seem realistic?
My assumptions are that the "owner" would do the work himself, that the owner may already have a Mikuni HSR42 and a RR3 that should be able to be reused, that brake performance is already in excess of OEM, and that the bike is in overall sound condition...
I'm assuming something would be prudent clutch-wise, and that chain drive may be desired but not required? What about the transmission itself? It will never be subjected to drag strip use, but would be ridden aggressively at times... It would also be used as daily transport often, and would occasionally be used for 3-4 day light touring, so adequate reliability would be needed.
Assuming "Project Creep" can be kept to a minimum, do you think it could be done for around $1000 after the cost of the engine?
Curious...
do it!!!!!!!! ultimate fxdx...
Maybe I'll try to find someone in the area to consult with...
Thanks again!
A lot of folks have also said "For what it cost me to build my XXX I could have bought the S&S 124 crate motor.
: Mike
