Sissy bar installation
Old Mar 14, 2017 | 07:22 PM
  #31
cggorman's Avatar
cggorman
Originally Posted by cvaria
just the dentist on speed dial
That's what helmets are for! Orthopedic surgeon, though, I got his number...
Old Mar 14, 2017 | 10:13 PM
  #32
kwrdkc's Avatar
kwrdkc
Originally Posted by TinCupChalice
If you remove the seat you'll see where the wiring from the fender is running in; simple disconnect/reconnect. The hardest part is getting your arm up under the fender and put the wiring back in the side channels but I'm a scrawny guy so it's pretty easy
The fender is held on by only the 4 bolts so if you're completely removing the docking setup be sure to put some towels between the tire and the underside of the fender to support the fender when it's loose to prevent any scratches; I can't tell you about how the dealer put in that relocation/docking, hopefully it wasn't necessary to make any cuts; I've never used it so I don't know.
With the stock sissy bar and rigid sideplates the connectors will come right out of the holes in the fender and strut with no cutting needed...
Edited to add:
No de-pinning needed, no cutting needed; the holes in the fender and strut are big enough that the connectors can come right out and back in; like I said, the hardest part of the entire job is getting the fender wiring back in to the side channels. A few Cirque du Soleil moves, and you've got it done
Doesn't look like the connector is going to fit through the bolt that's connected to the turn signal. Might fit through the docking point though. Looks like I will have to un-pin after all.
kreeess
Apr 26, 2014 01:52 AM
Port City Hog
Mar 4, 2011 02:10 PM
vicsponjr
Apr 23, 2008 10:57 AM
puddles13
Dec 14, 2006 12:47 AM
sims5
Jun 1, 2006 12:34 AM
