2014 FXDC VINERR Code error
Old Mar 18, 2017 | 07:05 PM
Grumpy007's Avatar
Grumpy007
Stage I
Default 2014 FXDC VINERR Code error
Had a fast idle problem. Next day engine check light came on while riding and the engine began to run rough for several seconds before running ok. Came to a stop light engine check light came on and ran rough then died. Was able to get it to a friends house. Then wouldn't restart had to trailer it home. Bike has 14000 on it and has stage one with a tuner. Was installed last year and more than 2000 mile ago. Any helpful information would be gratefully appreciated.
Old Mar 18, 2017 | 07:45 PM
Mchad's Avatar
Mchad
Vinerr is usually due to low voltage. I get it on my LRS at start from time to time when the started is straining. It happens when the rvoltage drops enough that the speedo loses communications with the ECM.
2014 isn't that far out of warranty. Maybe your dealer can help you out. Doesn't hurt to ask.
Old Mar 18, 2017 | 08:54 PM
Nickd2689's Avatar
Nickd2689
I get the same thing with my lrs when i start it in the colder temp ranges like 5-30 degrees.
Old Mar 20, 2017 | 05:16 PM
Smogbob's Avatar
Smogbob
Sounds to me like your battery is failing, even doing a test does not show it is failing, I would get a new battery and also change battery in keyfob, and I reckon all should be good.
Old Oct 11, 2018 | 01:19 AM
JohnnyFXDB's Avatar
JohnnyFXDB
6th Gear
I started getting this too. From what i've read so far, it could be the battery or the compression release is not working.
Old Oct 11, 2018 | 09:13 AM
Smogbob's Avatar
Smogbob
It is the battery weak, I sorted mine by putting a brand new stronger CCA battery after that no VINNER problems ever, except when I did not have a full charge on the battery, which proved to me problem was a dying battery, and battery was only 2 years old, however it was my fault because I let the battery over winter for over 3 months without charging, and the alarm draws power, so my own stupid fault.
Slice44
May 4, 2019 12:26 PM
DaveJFuller
Jul 1, 2014 08:53 AM
vickers1
Jun 14, 2014 09:33 AM
Kbore
Aug 26, 2009 02:56 PM
jb bill
Dec 26, 2005 05:28 PM
