Please help ?!?
Old Mar 19, 2017 | 03:12 PM
Iron2fatbob's Avatar
Iron2fatbob
Default Please help ?!?
Ok ... so this is what happened today
working around the house and I have had the bike hooked up to the battery tender but haven't started it up in the last month due to the weather and snow fall ...
started the bike up and 15 minutes later I walked back over to the shed and it was smoking a little, everything was really hot and the gas tank vent was hissing so when I removed the gap and the vapors or fumes pushed out so fast it sounded like a pressure relief valve failing on a gas line ... it was 38 degrees outside and the fuel level was on the lower end ...
any my ideas of what caused it ? It's not like I haven't idled the bike before to let it run I know it's air cooled but it's freezing outside and it's no doffeeent than idling in traffic for a few minutes ...
any thoughts as to why there was so much pressure in the gas tank ??
Old Mar 19, 2017 | 03:22 PM
Highwaymans's Avatar
Highwaymans
You've answered your own question.
Old Mar 19, 2017 | 03:25 PM
Iron2fatbob
ok that's pretty much what I thought but I've never experienced that before ... just the combination of all those factors ?
Old Mar 19, 2017 | 03:26 PM
jvella's Avatar
jvella
6th Gear
Check your gas tank air vent hose, it's possible a spider block it with a web.
Old Mar 19, 2017 | 03:28 PM
Highwaymans
Yep. Idling in a shed. Metal tank above a standing still air-cooled motor with low amounts of fuel, that'll dissipate heat poorly. I wouldn't make a habit of that. An idling bike in a shed with gas vapors blowing all over it isn't a good idea.
Old Mar 19, 2017 | 03:30 PM
TinCupChalice's Avatar
TinCupChalice
Why for the love of all things holy and dear would you even do this? 15 minutes? There is absolutely no reason to be starting your ride like this if you're not able to actually ride it during the winter; it's one of the worst things you can do to it.
Those heads get hot; I mean, hot without air flow. The heads heated the fuel and air in the tank, it's as simple as that; the fuel got hot and the fuel vapor and air began venting. Think pressure cooker; that hot vapor had to go somewhere.
Don't ever start you bike and simply let it idle during winter storage, I don't care what the temperature is; there is simply no reason to do this. And store your bike fully filled with fuel; you created a nice air gap in the tank with the tank not full then you let it get good and hot; that's why you had the issue you did.
And yet your exhaust and oil will still have condensation in it... oy vey...
Iron2fatbob
thank you ... I appreciate it !!
also as far as the vent, I could hear it hissing out of the vent which is why I opened the gas tank ... stupid decision thank you everyone
Old Mar 19, 2017 | 05:56 PM
Iron2fatbob
yea ... noted, it was stupid idk what I was thinking than k you for your quick response I appreciate it ! I was riding it until about 3 weeks ago when we got a dump of snow on the ground and freezing temps after a mild winter ... won't make that mistake again
Old Mar 20, 2017 | 06:22 AM
HrdNox's Avatar
HrdNox
The worst thing you can do in a situation like this is panic.
Old Mar 20, 2017 | 06:42 AM
Mchad's Avatar
Mchad
Just to say, (along with everyone else) - it takes at least 20-30 min of riding, (not idling) to get oil hot enough for the water to boil out. Idling for 10 min only adds to that water. I'm not sure you can even get the oil hot enough by idling, but that's a different question.
In the winters, I don't start my bikes until I can ride for at least a half hour. But with all the miserable salt and spray they put down around here, I don't ride until after a good rain anyway.
heavymetalthunder
Exhaust System Topics
Nov 26, 2011 06:53 PM
BugDr
Apr 19, 2010 05:07 PM
skim1420
Jul 10, 2009 12:32 AM
bL33d
Jan 22, 2009 08:54 PM
vernh59
Dec 3, 2005 12:46 PM
