Lucky Daves 13 Bars
Old Apr 10, 2017 | 10:27 PM
dlporter's Avatar
dlporter
At 5'9", I would go with the 13" bars. I'm 5'7" and I'm running 12" San Diego bars with no discomfort. In terms of vertical height, the 13" Lucky 13s are just slightly taller than mine.
Old Apr 13, 2017 | 11:45 PM
JuanderBoy's Avatar
JuanderBoy
Originally Posted by stonei3
Here's the 13" style.
Being 5'9" I'd go 11".
If you really want to nail it. Get the specs from the website (height and pullback) and mock up something that mimics those specs and test it out. Voila
What jack are you using? I have that popular red craftman, I modified it but it still doesn't fit right.
Old Apr 14, 2017 | 11:41 PM
stonei3's Avatar
stonei3
That's the J&S lift. No mods needed, fits well with the Dyna frame and is very sturdy. I'm a believer and would definitely recommend.
Old Apr 15, 2017 | 01:03 AM
StreetBobJonathan's Avatar
StreetBobJonathan
i'm 5'6" and went with 13" LD lucky 13's and they're perfect.
Old Jul 31, 2018 | 05:59 AM
rogermar1280's Avatar
rogermar1280
Stage III
Default Lucky 13 13”
hi there going to order bar s can u help me out on part # for barke line and clutch cables thank lucky 13 13”
i have the lowrider s
Old Nov 29, 2019 | 04:59 PM
ThrottleTwister's Avatar
ThrottleTwister
2nd Gear
Default What CABLE Length for Lucky Daves 13 Bars 13" height
Can anyone help me with the cable length for the Lucky Daves 13 Bars 13" height.
I have a 2014 STREET Bob running drag bars at present and all of my cables are perfect but definitely will not fit the new bars I have coming. Lucky Daves 13 Bars 13" height. Rev Zilla sells Burley Cable Kits but when I put in all of the info for my Dyna Street Bob The offer 12" 14" & 16" Cable kits.
If I order the 12" do you think that will be too short or since the LD 13 have a slight pullback they may fit perfect. Where if I order the 14" (seems correct) I should have a couple of inches of play. The 16" would be over kill So if you have installed these yourself what cables did you use. Thanks
Old Nov 29, 2019 | 05:32 PM
JuanderBoy's Avatar
JuanderBoy
Originally Posted by ThrottleTwister
Can anyone help me with the cable length for the Lucky Daves 13 Bars 13" height. Thanks
My recommendation is to have the dealership do that part.
I installed my risers and my bars, but one cable ended up being too short, so I took it to the dealership and they order and installed the clutch cable, even then it was too short and it started leaking. Because they did the installation they ore-order a longer cable and installed as well at no extra charge.
Old Nov 30, 2019 | 06:13 PM
ThrottleTwister
2nd Gear
Hello JuanderBoy, Thanks for the reply. I think I can handle the install just really need to know the length. Burly Bars sells a cable kit with all of the cables and wire extensions and I guess the 14" length for the Lucky Daves 13 13" tall for my 2014 Street Bob kit for T-Bars is what I'll go with $197. (on sale till Monday) for the complete kit thru Rev Zilla. I live on a small Island in the Caribbean and we don't have any HD Stealers here anyway. I have a friend coming down in a few week and he'll stuff the bars & cables in his suitcase for me as shipping to here is VERY expensive, for a bars & cable set (probably $125 to $150 bucks) just for shipping, import duties, Taxes, and whatever else they can invent to get your $$$$$ Again thanks for the reply, ThrottleTwister
Old Nov 30, 2019 | 11:21 PM
Dynaglide92's Avatar
Dynaglide92
If you have a street bob you should be able to get away with atleast 14” bars on stock cables. If not you would need +2 for everything
Old Dec 1, 2019 | 12:37 AM
ThrottleTwister
2nd Gear
Hello Dynaglide92
Wish it were true but my bike came from the Harley with Drag Bars & Stage 3 Kit.
The cables have just enough length for them, not even any slack there to play with.
I think the bikes that came stock with 10" Apes may work but not my Drag Bars,
Thanks for the reply,
ThrottleTwister
