M/C question
Old Mar 26, 2017 | 11:06 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by jqb12
So, before I proceed with the rebuild kit, I thought I'd try to rule some other things out. I pulled the front caliper and sprayed/cleaned it up real good with brake cleaner. Pistons seem to be operating fine. I just put a
new cover on the m/c, but it started raining like hell so I haven't been able to get out and ride it. If none of this makes a difference, I'll install the kit next.
Suggest you post up the symptoms - there several very competent / very willing to help out folks here in the dyna forum
May save you a little time / money
Ghost
Old Mar 27, 2017 | 12:21 AM
NORTY FLATZ's Avatar
NORTY FLATZ
How is your M/C bad?
What's it doing/not doing?
Old Mar 27, 2017 | 09:02 AM
jqb12's Avatar
jqb12
Ghost
I installed the Hawg Halters wide glide conversion kit to my 2012 Street Bob. All seemed to go well. But, I did a stupid thing in the process. I left my 3 inch risers in the handlebars and simply lifted them up over the front of the gas tank (covered of course), leaving the m/c upside down (several days also!), waiting for parts to arrive. So when I put everything back together, I couldnt get the front brake to stiffen up at all, figured I got air into it. Bled the hell out of it, both manually and at the local shop with a power bleeder - nothing. I can hear a "squirt"? type of sound when I pull on the lever. So, I pulled the caliper, compressed the pistons and cleaned them off real good with brake cleaner, and caliper seems to be fine. I was seeing a bit of fluid (very minor seepage) coming from the m/c cover, so I just replaced it with another black cover but has a different seal than the stock one did. Will try to get out and ride it after work, if weather permits.
I referred to this thread awhile ago on the dyna forum: "Leaking front master cylinder fix"
Old Mar 27, 2017 | 07:41 PM
aquadave's Avatar
aquadave
Brakes only slow you down and as long as you apply pressure to them they restrict how fast you go. I say remove the brakes completely to lighten the bike and relieve the engine to go faster
Old Mar 28, 2017 | 07:57 AM
jqb12's Avatar
jqb12
Yea, that'll fix it right up! Not for this bike though. I ended up removing the front brake from my other bike (pic). If something's gonna be on the bike, it pisses me off when it doesn't work.l
Dirt Farmer
Engine Mechanical Topics
Jan 15, 2015 03:44 PM
LonestarXL
Jul 25, 2014 02:45 PM
studiopeg
Dec 22, 2011 11:59 AM
hd4evr2008
Jun 7, 2010 10:21 PM
Kbore
Wheels/Tires
Mar 25, 2009 09:33 PM
