Battery fitment problem
Old Mar 29, 2017 | 08:30 PM
fixedmlc's Avatar
fixedmlc
Default Battery fitment problem
End of last season my original battery in my street bob began getting weak. This season, as I'm waking up the bike from winter sleep I order a Drag Specialties Performance battery from Dennis Kirk, using their fitment guide. Shows up quick, slp it on the trickle charger to top it off, then went to install it last weekend, it slides in the battery box 1/2 way and that's it. Stuck, too tall, won't go in any further. I tried to push in more (ok, knocked on it) and almost couldn't get it back out. Took it out, compared height to original battery, and sure enough it is taller than original.
Returned battery, will argue restock fee, but wondering if maybe just going with stock oem battery is the best idea?
Old Mar 29, 2017 | 08:37 PM
Nickd2689's Avatar
Nickd2689
I would. Unless you have a lot of aftermarket electronic acessories, I don't see any reason to go with anything other than oem.
Old Mar 29, 2017 | 08:39 PM
bigbadpoppa's Avatar
bigbadpoppa
Can't go wrong with oem if u keep it maintained ...but if u want a better one yuasa seems like the go to for most.
Old Mar 29, 2017 | 08:45 PM
confederate's Avatar
confederate
Most Wanted
Get a Yuasa GYZ20HL for your bike. Not only is it a perfect fit, it will start your bike like no other AGM battery can. I've used OEM batteries and Big Crank batteries and there truly is no comparison. I won't use anything else.
Old Mar 29, 2017 | 08:50 PM
fixedmlc's Avatar
fixedmlc
Thanks guys. I have no extra electronics on the bike, stock lighting, only occasionally hook up a power vision to update tune. What stores carry Yuasa? Just out of curiosity and for price comparison...
Old Mar 29, 2017 | 08:54 PM
Mchad's Avatar
Mchad
Amazon.com
Amazon Amazon
Old Mar 30, 2017 | 05:58 AM
1HD1C's Avatar
1HD1C
did you use their motorcycle fitment guide?? if that said it fit no restocking fee should be paid
Old Mar 30, 2017 | 06:08 AM
HKMark23's Avatar
HKMark23
X "x" for Yuassa.
To be absolutely sure of a fit note the Product Dimensions under "Technical Details" and compare this to your existing battery.
Amazon Amazon
Old Mar 30, 2017 | 06:18 AM
TinCupChalice's Avatar
TinCupChalice
Another Yuasa advocate here!
Best pricing I've found is at Phat Performance on the GYZ20HL: http://www.phatperformanceparts.com/.../yuasa-gyz.htm
The GYZ20HL fits correctly in the Dyna battery box; 320 CCA, 20 Ah. $86.95; add something else you need to your order so you can get the free shipping; there's always something else we need
Old Mar 30, 2017 | 07:05 AM
HKMark23's Avatar
HKMark23
Man,, that is an excellent price. If I were the OP, I'd jump on this and add a set of upgraded cables to the order to save shipping and to get even more oomph from that battery. Just my $0.02.
