Stock throttle cables
Old Apr 2, 2017 | 07:22 PM
Ettingerkoot's Avatar
Ettingerkoot
Stage I
Default Stock throttle cables
Do the stock cables come with silicon sleeves or do I have to lubricate them
Old Apr 3, 2017 | 11:33 AM
TUCCI's Avatar
TUCCI
I doubt it, lube em at the recommended service intervals.
Old Apr 3, 2017 | 11:44 AM
JohnMn's Avatar
JohnMn
You lube them. This is from the manual;
1. See Figure 1-29. Remove two screws (1) to separate the
upper handlebar housing from the lower housing.
2. Unhook each ferrule and cable from the throttle grip and
remove the throttle sleeve.
3. Apply a light coat of graphite to the handlebar and replace
throttle grip.
4. Put one or two drops of SUPER OIL (Part No. HD-94968-
85TV) into the housing of each cable.
5. When assembling the handlebar housing, tighten both
screws (1) to 35-45 in-lbs (4.0-5.1 Nm).
jf7689
EVO
Sep 11, 2018 09:17 PM
Hogpro
Oct 19, 2013 12:25 AM
CPObiker
Jan 17, 2010 10:57 PM
Tanxane
Nov 15, 2008 08:39 AM
roofer
Nov 15, 2007 11:22 AM
