Brake light stays on
Old Feb 22, 2018 | 08:11 AM
  #41
LAFO's Avatar
LAFO
Erik, try the WD-40 option.
Get a syringe, fill it with WD-40. Use a flash light and find a really small gap in the dust cover of the master cilinder. Press the brake so the cilinder is pushed in and leaves space for the wd-40 to enter. Move your face away and let go of the brake. Do a press release of the brake a couple of times so the oil moves all over the place. Repeat two or 3 times(it's a plus if youre able to flush the brake fluid as it will let you move the brake freely. then you can add fluid again.) Once everything is done and your brake fluid is at the required level, just ride the bike through city block (makes you use the brake more).
If doing this doesn't work, your brake cylinder was too corroded and wont fully come out and needs replacement.
If it works, in about a month or couple of weeks, inject some more. Ones is fine and no need to flush the system. Just make sure to press the brake while you fill with oil and remove your face once your about to release.
Hope it works.
Dont remember when i posted this solution but its been months since I've added wd-40 and its working great. Guess it was dust or corrosion.
Originally Posted by Erik Lundberg
I also did that. But now the problem is back. Had the whole master cylinder replaced on warranty in 2015. Last year I got the switch replaced and master cylinder rebulilt. Does not seem to last long.
Old Feb 22, 2018 | 09:01 AM
  #42
skid_pimp's Avatar
skid_pimp
I usually get about 3 years or so out of mine. I usually buy two or three master cylinder rebuild kits at a time, and rebuild it and clean the pistons in the caliper whenever it acts up (like right now as a matter of fact). Then I flush all the fluid when I bleed the brake, flush and bleed the rear for good measure, and go ride..... it takes me about 45 minutes or so, being careful and taking my time, and with fluid and parts, cost under $20 or so.
Old Mar 14, 2018 | 12:02 PM
  #43
Erik Lundberg's Avatar
Erik Lundberg
I bought some WD-40 and lubricated the cylinder. Now it works fine again. Will be interesting to see how long time it lasts.
Old Mar 14, 2018 | 03:02 PM
  #44
NORTY FLATZ's Avatar
NORTY FLATZ
You realize the propellants in WD-40 can have a drying effect on rubber?
WD-40 is a "water displacement" product. Not really a very good lubricant. Maybe a "chain wax" product would be better suited? But, there again, it'll likely have n-propanol and that's very drying.
Old Mar 14, 2018 | 03:19 PM
  #45
cggorman's Avatar
cggorman
OEMs use silicone grease. It's available at most auto parts stores. I have at least three grades laying around. Shin Etsu is quite good for weather stripping...low friction and not terribly sticky (not AS bad with attracting dust). I think it has a teflon additive. Never tried it on a master cylinder, tho. I just found Shin Etsu this year. Til now I've been using a very high viscosity (and sticky) DuPont high vacuum grease. I use it on most anything rubber or plastic that needs lube.
At my last job we manufactured systems (that had to be Helium gas tight) with rubber seals and we used literal tons of various Dow Corning silicones. Both oils and greases.
Old Mar 14, 2018 | 03:21 PM
  #46
Rt13MFer's Avatar
Rt13MFer
Had the same problem. Master cylinder rebuild will happen soon but in the mean time, I shot a TINY burst of WD40 in where the brake lever pushes in the plunger and work the brake lever in and out a bit. Its a short term fix, but I did it last fall and its still working.
Old Mar 14, 2018 | 03:59 PM
  #47
Erik Lundberg
Master cylinder rebuilt last spring and brake light switch replaced. Didn't last long. Hopefully WD-40 will keep it alive.
Old Mar 14, 2018 | 04:04 PM
  #48
cggorman's Avatar
cggorman
WD40 is a **** solution. You're better off with cable lube or even motor oil.
Old Mar 14, 2018 | 04:11 PM
  #49
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
Isn't this forum great?! I feel confident that I can fix anything that goes wrong with the bike with the help of these guys.
Old Mar 14, 2018 | 04:23 PM
  #50
Erik Lundberg
"wd-40 it all."
"Erik, try the WD-40 option."
Ok so I bought some WD-40.
Then:
"WD-40 can have a drying effect on rubber"
"WD40 is a **** solution."
