LRS 117 c.i. ......clutch
Old May 2, 2017 | 02:21 AM
sempai's Avatar
sempai
Default LRS 117 c.i. ......clutch
Hi,
there's someone with the 117 that have some problems of slipping clutch (
Clutch that tends to slip) .....?
Thanks a lot
Old May 2, 2017 | 01:57 PM
gartec81's Avatar
gartec81
Options:
Get a clutch that hat doesn't slip and is rated for the hp and tourque
Stop practicing wheelies
Have a strong talking to with it before riding to let it know you are not happy with its performance
Put some duct tape around the basket to ensure it won't slip and has proper grip
Old May 2, 2017 | 02:18 PM
Mchad's Avatar
Mchad
Originally Posted by sempai
Hi,
Thanks a lot
A little hard to follow due to the language barrier, but doesn't the 117 kit come with a heavier clutch spring? Was that installed?
Old May 3, 2017 | 01:32 AM
sempai's Avatar
sempai
...sorry but the technical language isn't easy.......
In the 117 kit there is a "heavy duty clutch spring" but - with these results - i thing it doesn't work right.
But no one has the same problem ?
PS: i don't do wheelies.........
Old May 3, 2017 | 09:00 AM
sharkey's Avatar
sharkey
My favorite performance HD dealer here sold 120R Road Glides with shop warranty to select customers. His builds use SE clutch spring and proper clutch setup. These are 900lb bikes, usually with some big riders and passengers. I had a 111HP/117FT LB 103 FXDXT for years with only the SE spring; again, proper clutch setup. My buddy had an Independant shop build a 124 for his Road King; another heavy bike, and the aftermarket clutch slipped in that...improper setup. Make sure you have the SE spring; I think there's an extra plate in the kit now, too. Make sure the clutch is set up according to factory procedure...there is no shortcut or other way to setup properly.
Old May 3, 2017 | 09:04 AM
hometeam's Avatar
hometeam
H-D bolt-on 117 kit does not include a clutch spring. I'm not having any clutch problems with mine so far.
Old May 3, 2017 | 09:22 AM
sempai's Avatar
sempai
Yeah, you're right!! i've now controlled on the SE advertisement and only the "race Kit" include a heavy clutch spring ...............
The different between the "race kit" and the "Street Performance Kit" is the.....heavy clutch spring.
Shameful.
Old May 3, 2017 | 09:34 AM
sempai's Avatar
sempai
The difference between the "race kit" and the "Street Performance Kit" is the.....heavy clutch spring.
Shameful.
Old May 3, 2017 | 10:16 AM
cvaria's Avatar
cvaria
The se clutch spring is ~$35. Slap that thing in there
Old May 3, 2017 | 12:22 PM
hometeam's Avatar
hometeam
Shameful.
I'm sorta right. I amend my post. "MY" H-D bolt-on 117 kit does not include a clutch spring. ;-)
