Dishwasher...
Old May 9, 2017 | 02:27 PM
F86's Avatar
F86
Default Dishwasher...
Hey... Sometimes I have ideas that end up being really stupid and causing lots of regret, so I thought I would just check with everyone first...
I just got parts back from powdercoating (upper and lower rocker boxes, pushrod tubes, lifter blocks). They came back pretty well cleaned, but I obviously want to wash them well before using... I was planning on bringing them to work where we have a parts washer, but I always think the fluid is filthy... Any reason I can't just put them all in my dishwasher at home? If so, can I use regular dish soap?
Come to think of it, I was going to bring my recently-machined cylinders, heads, and intake manifold to work as well for the same reason... Can I put everything in the dishwasher (none of it is greasy at all)?
Is this actually a Wile E. Coyote sort of idea?
Old May 9, 2017 | 02:35 PM
cggorman's Avatar
cggorman
Hand dish soap is too foamy. Machine washing liquids I've used are pretty corrosive. Laundry detergent (just a tablespoon or so) works pretty good. Be aware that you run the risk of rust/oxidation due to the water. Keep the cycle time short as possible and blow dry ASAP.
Engine parts with bare aluminum and steel are probably not great candidates for the dishwasher. I'd strongly recommend trying it with a few non-critical test parts first to be certain you can deal with the results.
Old May 9, 2017 | 02:39 PM
cggorman's Avatar
cggorman
I have one of these that I use all the time for all sorts of stuff. I LOVE IT!
That's a Snap-on. Mine's a Matco. Same thing. https://www.matcotools.com/catalog/p...NG-SIPHON-GUN/
Old May 9, 2017 | 02:41 PM
F86's Avatar
F86
Okay... Maybe I'll just lug everything to work and back as I originally planned...
Thanks.
Old May 9, 2017 | 02:42 PM
F86's Avatar
F86
Is that a wand for the parts washer?
Old May 9, 2017 | 02:51 PM
cggorman's Avatar
cggorman
You connect the handle to an air compressor and the rubber siphon line goes in a solvent or soap solution. It shoots a stream of solvent in similar fashion to a pressure washer but no water needs to be involved. I use mine for every type of part and equipment cleaning imaginable. I've sprayed everything from acetone and mineral spirits to insecticide and simple green. It's hands-down one of my most-used air tools.
Google "pneumatic solvent sprayer"
I really like it for engine parts because I can use nothing but virgin solvent and dry air (I have a dryer after the compressor then two regulators, one with an oiler for rotor tools and one without for sprayers.)
Old May 9, 2017 | 03:13 PM
cvaria's Avatar
cvaria
Not so old s&s guy used dish soap and water and followed up with atf and towels.
here, arouubd 21:00-
Old May 9, 2017 | 03:16 PM
cggorman's Avatar
cggorman
Yep, soap and water is fine, but you gotta be Johnny on the spot with drying and rust preventative. Cast iron/steel rusts like a SOB. Usually can be wiped off with a towel and light oil, but I prefer to skip that rusting step.
Old May 9, 2017 | 03:20 PM
TriGeezer's Avatar
TriGeezer
They aren't huge parts. So why not clean them by hand. I've found WD40 to be a great cleaner of chrome parts. Maybe it will work well on powder coated parts as well.
Old May 9, 2017 | 03:21 PM
cvaria's Avatar
cvaria
I was surprised how fast the rust started when i washed out the new sportster cylinders.
