Progressive monotube clunk?
Old Jun 19, 2017 | 01:33 PM
Dynaglide92's Avatar
Dynaglide92
Default Progressive monotube clunk?
Recently installed a set of progressive 49mm monotube kit and the darn thing makes a clunk sound when going over bumps in the road. Has anyone had these installed and have the same problem? It's annoying as hell and just doesn't sound normal. Will be calling progressive to see if this can be resolved. For now I wouldn't recommend.
Old Jun 19, 2017 | 10:52 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Check the forward and rear tank mounting bolts before you call anybody!
Old Jun 20, 2017 | 12:35 AM
Synstars's Avatar
Synstars
Keep us posted!
Old Jun 20, 2017 | 01:51 AM
canyoncritter's Avatar
canyoncritter
The bolts up threw the legs tight?
Old Jun 20, 2017 | 05:38 AM
robertomendo's Avatar
robertomendo
Check the bolts that connect the gas tank to the motorcycle! One on the front of the tank and one on the rear of the tank. Nothing to do with the forks but if one or both are loose that might be the source of your clunk.
Kind of like OldEnuf2NoBtr says!
Old Jun 20, 2017 | 06:33 AM
Davdoodles's Avatar
Davdoodles
Yep, +1 agree re checking for loose gas-tank bolts.
I swore, swore that it was the forks that were clunking, that's where the sound seemed to be coming from. I went over everything, tore my hair out, but it was the front tank bolt.
Darndest thing.
Old Jun 20, 2017 | 11:51 AM
Steelfisher's Avatar
Steelfisher
6th Gear
No clunk, but mine started making a metal on metal squeak followed by a "click" on compression. To be honest, it always felt mushy and unstable to me to begin with. Previous owner had it installed, so no warranty for me. I'm 6'2" and 300# so maybe I was asking too much of the one size fits all solution. I ended up pulling the monotube kit out and going with some Heavy Duty springs.
Old Jun 20, 2017 | 04:54 PM
Dynaglide92
torqued to spec so yes will recheck to see if anything came loose
Old Jun 20, 2017 | 04:58 PM
Dynaglide92
Originally Posted by Steelfisher
No clunk, but mine started making a metal on metal squeak followed by a "click" on compression. To be honest, it always felt mushy and unstable to me to begin with. Previous owner had it installed, so no warranty for me. I'm 6'2" and 300# so maybe I was asking too much of the one size fits all solution. I ended up pulling the monotube kit out and going with some HD springs.
yes yes that's the noise I get under compression it clicks /clunks when the forks are compressed too fast such as going over bumps fast it's so frustrating
Old Jun 20, 2017 | 10:15 PM
MRFREEZE57's Avatar
MRFREEZE57
how do you like them after finding the noise?
