Adjusting speedometer with PowerVision
Old Jun 29, 2017 | 09:19 PM
Reindeer's Avatar
Reindeer
Default Adjusting speedometer with PowerVision
Haven't got much action in the tuner section, and I know there's more than a few PV users here.
Anybody know the method for recalibrating the speedo using the PowerVision? I haven't played with it much, other than figuring out the gauge displays, and of course having it dyno tuned, but I don't see where to adjust it, nevermind how to actually do it.
I'm running a 30/68 pulley combo, and my speedometer is definitely not accurate now.
Old Jun 29, 2017 | 09:42 PM
cvaria's Avatar
cvaria
the VSS setting in quick tune and trial and error with a gps speed app on your phone. not iron clad but, that's what i had to do when a tune randomly wiped my VSS values.
https://www.hdforums.com/forum/dyna-...l#post14913390
Old Jun 29, 2017 | 10:09 PM
Reindeer's Avatar
Reindeer
Thanks. Found the VSS setting. If the speedo reads faster than my actual speed, should I go up or down? Once I make the change, do I just hit save and then it loads the change?
Old Jun 29, 2017 | 10:40 PM
cvaria's Avatar
cvaria
i'd be lying if i said i knew. see post 7
http://www.harleytechtalk.com/index.php?topic=82389.0
Old Jun 29, 2017 | 10:51 PM
Suede Blue Man's Avatar
Suede Blue Man
If all you changed was the front pulley like I did (to a 30t), then set your VSS to 2280, up from the 2146.
I have since verified this using the GPS in a cellphone, I imagine it was quite accurate.
I learned this from Pilot so you know it's right
If you changed the rear pulley, message Pilot
Old Jun 29, 2017 | 10:58 PM
Reindeer's Avatar
Reindeer
Excellent. Thank you.
rwven
2014-2024 Touring Models
Nov 11, 2017 05:31 PM
racklefratz
Jul 27, 2017 06:40 AM
Reindeer
Jun 30, 2017 10:22 AM
tc88hog
Dec 29, 2014 05:38 PM
kipd
Jun 23, 2014 08:57 AM
