2014 FXDF Rear Brake/Turn Light?
Old Jul 7, 2017 | 11:02 AM
fhartell14's Avatar
fhartell14
Default 2014 FXDF Rear Brake/Turn Light?
I have a 2014 FXDF and I'm wondering if there is an adapter that would make the 2 brake lights also act as separate turn signals?
If not what adapter are folks using for the turn signals to act as brake lights?
Old Jul 7, 2017 | 11:46 AM
nevil's Avatar
nevil
I use one that I got from Biketronics. Simple plug and play but you have to change the brake light bulbs to red. Others have had good experience with Custom Dynamics
Old Jul 7, 2017 | 11:48 AM
DynaDownLow's Avatar
DynaDownLow
Check with Custom Dynamics or DK customs, if anyone had something, they would.
Old Jul 8, 2017 | 09:03 AM
sparkalot's Avatar
sparkalot
You might try this product https://www.customdynamics.com/eclipze2-module I am a Custom Dynamics fan because they are very helpful with questions.
This has been coming up alot lately
Also see this post https://www.hdforums.com/forum/elect...ed-system.html
Have fun doing your mod, let us know if you need more help
Old Jul 8, 2017 | 09:56 AM
NorthWestern's Avatar
NorthWestern
They cannot be programmed to do so? My stock lights did that, and when I switched to a full fender and taillight, my turns still have the brake signal. I like it
Old Jul 8, 2017 | 11:48 AM
sparkalot's Avatar
sparkalot
Possibly.....yours and his bikes are newer than my 2009 FXDF. so maybe there is a way to set a jumper or something...my FXDF had a "circuit board" in the stock rear tail light that I cut off. When I changed the fender to a new Wide Glide fender, I kept the old rear harness but cut all wires and rewired everything back there from scratch......alot of folks don't want to get into that kind of thing so hopefully there is a simpler way.
Re reading fhartell14's post, now I am thinking he wants to use the dual round LED brake lights on the newer FXDFs each as a turn signal. Unless there is a way to program it as you said, the wires for the brake/run light in each of the two lights light would need to be separated, and no longer common to each other, so that the brake wire from each side is now separate, which would allow either a brake or turn signal to be applied to the brake LEDS........best thing would be to call Custom Dynamics or another vendor with a similar device and ask them
Cheepwhiskee
Electrical/Lighting/Alarm
Jul 5, 2017 02:52 PM
14StreetG_cruiser
Mar 27, 2017 11:06 AM
joebedford
Aug 1, 2015 06:41 PM
martinez_nc
Jan 13, 2009 07:33 PM
don03
Aug 15, 2007 10:11 AM
