Help with 02 superglide
Old Jul 18, 2017 | 07:37 PM
Derekm658's Avatar
Derekm658
Stage III
Default Help with 02 superglide
hello there! Recently purchased an 02 superglide with 11,000 miles, recently got into riding, having a loss of power issue when motorcycle gets warm, idles fine but as soon as engine temp rises I'm having a complete loss of power, motor quits, no power...nothing, let it sit for 5 minutes and it fires right up, take off again and experience the same problem, any guidance as to where to look would be very helpful, thanks Derek
Old Jul 18, 2017 | 10:33 PM
Hondahawkrider's Avatar
Hondahawkrider
i would check the tank.. An 02 with 11k isn't many miles.. I had a similar issue on another bike years ago. Same thing would happen when then petcock was on main, but not prob on reserve. There were particulates in the tank (old gas gets gummy) than would get stuck on the screen after it started sucking in fuel when on main, starving the bike of fuel..If it sat, the crap would float to the bottom of the tank and it would start again no prob... I emptied and acid cleaned the tank, and put a fuel filter between the tank and carbs. The later more so I could see fuel going to the carbs..
Also, if you find anything in the tank, there might be some crap in the carbs as well, which could do the same thing. So if you do have to take the tank off to empty/clean it, might be worth cleaning the carbs...
Old Jul 19, 2017 | 05:18 AM
cutter4292's Avatar
cutter4292
check the coil (spark) also.
Old Jul 19, 2017 | 05:46 AM
Iceman24's Avatar
Iceman24
First post...I'd look t the dealer's service dept for aid.
Old Jul 19, 2017 | 06:53 AM
Derekm658's Avatar
Derekm658
Stage III
sorry, I guess I should be a little more specific, when I'm saying it has a "loss of power" I mean everything goes out, motor, lights, everything...almost as if you shut the key off, I was hoping by posting maybe someone had experienced similar issues that they have resolved and if there was a common problem...just looking around the forums I've came up with a few guys that had complete loss of power problems stemming from bad battery cables and bad ignition switches.....I appreciate the help! Keep it comin!
Old Jul 19, 2017 | 07:27 AM
Campy Roadie's Avatar
Campy Roadie
First things first.
Check the battery cables and ground (both ends).
Check the battery voltage, static and under load.
Check continuity/integrity of the ignition switch.
Until you do these things, you and everyone else will just be guessing. PS, when you do find the problem, report back so someone else might benefit from your experience. Don't be a one and done poster.
Old Jul 19, 2017 | 07:59 AM
Derekm658's Avatar
Derekm658
Stage III
Nomadmax-appreciate the tips!! Will check it out tonight and let you all know what I find! Thanks again
Well I appreciate the responses to my post! Let me re-cap on this, I was experiencing a complete loss of power(motor and electric)
after engine temp was hot( both at idle and while riding) let it cool off and it would fire up and idle until temp reached a certain point, this is an 02 superglide with 11,000 miles, nomadmax steered me in the right direction along with some input from a few friends who are way more knowledgeable than I when it comes to motorcycles, found a loose cable on the circuit breaker and alls I did was tighten it up, seemed to fix the problem, idles great, no issues riding...sorry about the picture being in the middle of the post
Old Jul 20, 2017 | 07:09 AM
Campy Roadie
GREAT JOB!
Welcome to the forums.
Old Jul 20, 2017 | 02:24 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Hey OP, take note what wire goes to what post on the circuit breaker for future events. The 02 FXD is a real work horse, you'll enjoy it like I do mine.
LDB187
Jul 1, 2016 07:25 PM
Jacoblb
Nov 25, 2012 02:41 PM
Susie B
Sep 16, 2009 10:06 AM
3rdgear
Aug 22, 2009 05:49 PM
bartles
May 15, 2008 12:31 PM
