Bizarre Transmission Issue (Help Needed)
Old Jul 22, 2017 | 06:18 PM
BMCsteve's Avatar
BMCsteve
Default Bizarre Transmission Issue (Help Needed)
Hey guys, I've been having some weird shifting problems for the last 500 miles or so that seem to be getting worse. I tried researching this issue and haven't had any luck. Hoping someone here can help
When I'm downshifting from 3rd to 2nd, I basically get stuck in 2nd until I let the clutch out again. Before I let the clutch out, there is a ton of play in the shifter and I can't downshift to 1st and can't go into Neutral. It's just kind of a dead floppy shifter until I let the clutch out, then I can go into N or 1st.
That's my best description. Hopefully someone can help me figure out what's going on. The clutch adjustment feels perfect. I've tried adjusting it both ways as well and it didn't change a thing.
thanks
Old Jul 22, 2017 | 06:33 PM
BMCsteve's Avatar
BMCsteve
more info that might help. this happens when I'm downshifting and slowing to a stop, not when I'm stopped. In 2nd, i would describe the shifter as "limp"
Old Jul 22, 2017 | 06:53 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
A couple of things to look for 1) is the shift outside of the trans. slipping on the splined shift shaft? 2) this is in depth, the shift pawl may have slipped out of adjustment. Maybe some one with trans. work can help you with the shifter pawl. I think the shift lever has an allen bolt on the splined shaft.
Old Jul 22, 2017 | 07:10 PM
RANGER73's Avatar
RANGER73
Not sure on your bike, is it a cable or hydrolic cluch?
Sounds like your cable is hanging up.
Old Jul 22, 2017 | 08:05 PM
misfitJason's Avatar
misfitJason
5 or six speed trans?
Old Jul 22, 2017 | 09:54 PM
BMCsteve's Avatar
BMCsteve
sorry, that info would be helpful. its a 2016 FXDB (6 speed, cable clutch)
Old Jul 22, 2017 | 10:18 PM
archergodwin's Avatar
archergodwin
Check the things that seniorsuper listed...
Old Jul 22, 2017 | 11:59 PM
BMCsteve's Avatar
BMCsteve
Thanks man. just checked and the shifter is still tight on the splines. the allen bolt is still in place.
still cant figure this out
Old Jul 23, 2017 | 02:40 AM
Nemosengineer's Avatar
Nemosengineer
If your under warranty, get to a dealer. There are three springs in the six speed tranny, the loss of any one will make for strange behavior, the good news is the parts are cheap IF it's a spring issue, the bad news is the transmission comes apart to replace some of these springs.
#1 Spring, shift lever centering P/N 34064-00C $4.00
#2 Spring, ratchet lever P/N 34987-06 $2.00
#3 Spring, detent P/N 33389-07 $4.49
Link to Ronnies Parts Finder, go to "Gear Shifter Assembly" to see what I'm talking about:
http://partsfinder.onlinemicrofiche....TER%20ASSEMBLY
Old Jul 23, 2017 | 04:31 AM
Warp Factor's Avatar
Warp Factor
Also check to see that all parts of your shift linkage are completely free, with no tightness or binding. A little binding can make it so that the linkage won't return all the way, making your next shift inaccessible.
