Valve stem size?
Old Jul 31, 2017 | 07:35 AM
HyperM3's Avatar
HyperM3
Default Valve stem size?
Im trying to get 90 degree valve stems for my 2013 FXDF from Kurveygirl and I have come across an issue. Their fitting guide says that for the cast wheels it's two different sizes. However, for the slotted wheel its one size.
Im looking in the manual and it describes my wheels as slotted cast wheels!?!
So for anyone who has replaced their valve stems, please clarify. And for the record, my local HD service department couldnt help me out.
Old Jul 31, 2017 | 10:13 AM
cggorman's Avatar
cggorman
http://shop.outpostalaska.com/OEMpartfinder.htm
Based on the OE stem part numbers from the link above, you need the dual size kit.
Got a set of calipers? Should be easy enough to verify by measuring the hole in the rim.
Old Jul 31, 2017 | 07:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Prior to driving off, make sure it will clear the brake caliper.
Old Aug 1, 2017 | 06:46 PM
HyperM3's Avatar
HyperM3
I ordered my stems from Kurveygirl and they were awesome. They were kind enough to send two of the same size and one of the other size so I could just return the one I wasnt going to use.
Regarding clearing the caliper, Im going to have them position the stems so they are parallel to the wheel instead of sticking out.
mrfikser
May 2, 2015 08:38 PM
big gar
Apr 17, 2011 05:11 PM
nerider2
Aug 15, 2008 09:12 PM
Rynb15
Mar 26, 2008 01:59 PM
Corndog
Jan 12, 2008 04:27 PM
