It's your money, but why not wait and try out the stock set up after you've adjusted it for your weight? Then when (and if) you start dragging parts punching it through the twisties, you can easily upgrade.
I test rode the same model and was scraping the pegs so shock length is an issue I already know about
I am sorry but we are in a different time zone than you in AU. I started on e-Mails at 7:30 am our time and have replied to your questions. If that is not totally answering your questions than please just ask exactly what you want me to answer. I do have a pair of brand new black lines shocks I am re-valving for a customer apart right now and can take pictures specifically of that HD-774 & the HD-159 models if needed for a good reason. I am here all labor day weekend.
Thanks Howard. I didn't think there was any unreasonable delay in your reply and understand you're busy. As it turns out I didn't realise your email reply was inadvertently directed into my junk email folder (sorry my bad). So I found it this morning and will read and consider. Thanks mate for the quick turn around.
I also have a lrs and I've never even adjusted my rear shocks. 13,000 miles and I have no complaints at all. There's nothing wrong with exploring your options but it will be an expensive upgrade though so I would suggest you at least try the factory shocks with an open mind. I'm sure tin cup will chime in on this one and he has a lot of knowledge on this topic. I was actually just talking with him about suspension and brakes. It'll probably be a really long message cause there's a lot of info, but definitely worth the read. I'm pretty sure when Google needs to know something, it asks tin cup lol.
Thanks I'm keen to hear any and all input.
There are mixed reviews of the oem emulsion shocks but even if they were really good the length is an issue, at least for me
OP, I get what you are thinking, and as one who came from late model liter+ bikes, I immediately thought I was going to need an upgrade on the shocks, and eventually it will happen.
My suggestion is that you give the stock stuff 1000 miles of you wiping the chicken strips off the tires, and see what you think. My opinion is that you will be spending money elsewhere on the machine
Thanks but I'm thinking a longer shock will provide a bit more ground clearance and cornering
I wouldn't even call the factory oem shocks , shocks. More like 2 moving sticks. Anyone that has ever ridden performance bikes will always change the shocks. Its not only great for aggressive rides, it also smooths out the bumps entirely. It's night and day when you compare comfort between oem and aftermarket.
I tend to agree although admittedly I haven't spent much time riding on these emulsion shocks of Harleys beyond test ride but they could have added some length
Originally Posted by bigbadpoppa
Forgot to answer your question.
1. LEGENDS is another brand, but I'd go air suspension if you choose them. That's what they are known for but they do have coil shocks.
2. Piggybacks functionally won't do much. The design of it is to cool off constant up and down movements like dirtbiking . Doesn't sound like you'll be knee dragging corner after corner on a track.
Thanks and agree that piggybacks probably aren't necessary for me
Pretty hard to answer questions from tomorrow. Remember talking to my wife on the phone from Aussie land, a bit weird with the time zones. From my experience with a Dyna Super Glide and a Dyna Low Rider, the L/R isn't as quick in curvy situations due to the bikes geometry. Did you test drive a L/R against a S/G on the same roads?
Superglides haven't been a popular harley in Australia for a while now. My dealer hasn't stocked one for a while and they dont have a demo either. If you want one you've gotta put a deposit down and order one or test ride a private seller's bike. I think that's the case at most Australian dealers
The stock emulsion shocks are pretty good, for HD standards they are excellent. They just lack length.
Scraping pegs can be solved in the short time with a set of tapered pegs like the thrasin supply co ones or from Speed Merchant, easy way to get another degree or two for cheap.
You can also use the bung king shock riser which bolts to the lower shock mount giving 1.75 inches more lift.
