Battery Shorted
Old Oct 1, 2017 | 04:55 PM
razorbacksrule13's Avatar
razorbacksrule13
2nd Gear
Default Battery Shorted
Lost a bolt on the battery box on my 2005 Dyna Low Rider and the positive terminal touched the frame and killed all power . Where should I look first fuse box ?
Old Oct 1, 2017 | 09:39 PM
skinman13's Avatar
skinman13
I don't have a wiring diagram for an '05 in front of me but you might have blown the main fuse. Look for a 40A fuse probably located in the fuse block...
Old Oct 2, 2017 | 01:52 PM
razorbacksrule13
2nd Gear
Ok checked fuses replaced them to be sure . Also replaced battery still totally dead what should I look at next .
Old Oct 2, 2017 | 02:17 PM
Mchad's Avatar
Mchad
Check your ground cable. May have fried it dumping your entire battery through it.
Old Oct 2, 2017 | 02:26 PM
d_slat's Avatar
d_slat
Here's your answer. Check neg. batt. cable and connections at BOTH ends.
Old Oct 2, 2017 | 05:50 PM
STRES's Avatar
STRES
I would grab a DMM and check your voltages to GND everywhere you can, fuzes etc.
Old Oct 2, 2017 | 06:36 PM
rkoivisto's Avatar
rkoivisto
Default Short Circuit
The positive terminal grounding will not blow any of your fuses.
The current will flow through the negative (ground) side, so as said above check both sides of the negative. If the engine was running, you could have fried your regulator also.
Did it take the battery out?
Old Oct 2, 2017 | 07:18 PM
razorbacksrule13
2nd Gear
Default Battery
Yes it took the battery out was brand new too ! I just bought the bike and previous owner had just installed it . He gave me the reciept so I took it back and they gave me a new one . Also it seems like the battery is to tall I double checked the size and it's right called the Harley shop to verify it .
Old Oct 2, 2017 | 07:37 PM
d_slat's Avatar
d_slat
But you said you already replaced the battery and it still didn't work?!?
Old Oct 2, 2017 | 08:20 PM
razorbacksrule13
2nd Gear
Yes replaced battery and still no power . Didn't have time to work on it tonight I'll check the negative cable tomorrow .
bobby5
Mar 30, 2013 11:23 AM
TattooBill
Aug 18, 2011 09:04 PM
34 dd
Dec 1, 2009 03:23 PM
Dragan
Aug 17, 2009 07:14 PM
SportyCustom
Apr 1, 2009 08:04 PM
